i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Hot wash, hot rinse is for 'whites'. Cold wash, cold rinse is for 'colors'. Warm wash, cold or warm rinse is for 'permanent press'. Check your settings to see if you have these options. Double check the hoses, put the machine on cold fill and feel the hoses. Has someone worked on the machine and possibly put the wires on the solenoids wrong? Easy mistake to make.
I am going to guess you run a warm wash, and cold rinse. This sounds like the screen on the cold water inlet is clogged. Shut the water off and remove the hose at the back of the machine. Look in the water inlet and see if the screen is clogged. If so, carefully scrape it as clean as you can. Use a straw and blow into it to help clear it out. Replace the hose and try it. It does not need to be perfectly clean, but at least half way opened will suffice.
you will need to put a "Y" in the cold water line and remove the hot water hose otherwise the hot water solenoid will open up and let in hot water,if you have cold water to both solenoids then you can get done what you want to accomplish,wash and rinse in cold water on all cycles
Washers are meant to rinse in cold water, so clothes should come out cold.
If you are not sure if it is getting hot, then select a very hot wash, and feel the door glass periodically, it should gradually get hotter, if it does not , then it is washing in cold water only.
This could mean that the heater element has gone.
Plz rate my solution.
Thanks.
It sounds like you have the hot and cold water lines to the washer reversed.
Try turning off the tap for the hot water then setting the washer to just cold wash and then hot washif you get nothing on the cold and cold water when set to hot they are probably reversed. Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
