20 Most Recent
Zanussi ZWD1270 Front Load Washer / Dryer Questions & Answers
Zanussi ZWD 1270 no heat
E72 can also be caused by broken wiring to the NTC(Sensor). If the wiring is low voltage( very thin wires) then pull gently on the wires where they go into the NTC. If they break away there is the problem, you would need to replace the wiring harness for that NTC. Also, check the fan motor is running and the belt on the ventilator has nt stretched. If all is ok check the condenser is nt blocked with lint
My zanussi ZWD12270G1 wont turn on
THE MOTHERBOARD MIGHT HAVE FUSED OUT , NORMALLY YOU HAVE TO TAKE THE TOP OFF AND LOOK FOR A FUSE NORMALLY A 4amp LOOKS LIKE A GLASS FUSE LET ME KNOW
Water standing in bottom of
(pre-typed 'cos I can't type this fast!!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Washing comes out covered in fluff and bits after
check to make sure that the lint trap is clean and clear -- also check the exhaust hose and outside vent for any obstructions. also check the vent holes that lead to the lint trap -- sometimes these can become plugged up with fibers and not lint out the wash proper.
c...
Door on washing machine is locked with e20 code
This particular code is used when the machine detects a pump problem or water draining problem. In this case, the fault would occurr just before attempting to spin. It turned out to be a blocked filter, accessible from the bottom front of the machine. so the best thing to do is clean the filter on the front of the machine open the flap and undo the filter water will come out so be ready for that. after it is cleaned and filter all back in and secure switch machine back on at plug and run cycle this should fix it. hope this helps.
Here are some error codes for future problems.
E10 - not filling
E20 - not draining
E40 - door open
EFO - Filter blocked
ZANUSSI ZWD162701 washing always comes out cold - WHY?
Washers are meant to rinse in cold water, so clothes should come out cold.
If you are not sure if it is getting hot, then select a very hot wash, and feel the door glass periodically, it should gradually get hotter, if it does not , then it is washing in cold water only.
This could mean that the heater element has gone.
Plz rate my solution.
Thanks.
Washer dryer is no longer drying
two things to check
take rear half of cabinet off and check the dryer duct (lhs from front) is not blocked. this is very common
check water is being taken in during dry - the water is used to condense steam from the drying clothes. easiest way to check this is to see that some water is being drained during the drying cycle.
i assume that drain is operating ok
Zanussi Washer dryer ignoring all programs and just does a pulsing humming sound (Only works well on reset mode)
It seems like you've done a thorough job troubleshooting so far. The E69 error could be related to a heating issue. Since you've already replaced the heating element, it's worth checking the thermal fuse. The thermal fuse is a safety device that can sometimes cause E69 errors if it's faulty.
Given that you have access to a spare machine, you might consider swapping the thermal fuse from the spare machine to see if it resolves the E69 error on your primary machine. If the spare machine's thermal fuse is in good condition, it could be a step toward identifying and solving the issue without having to switch the drums.
Remember to disconnect the power source before attempting any replacements, and I hope this helps you get your tumble dryer back in working order.
