20 Most Recent Electrolux EW1200i Front Load Washer / Dryer Questions & Answers
6 years old - probably the wash tub bearings gone. Does the wash tub lift up and down from the front? sure sign bearings have gone. Would you drive a car at 70mph if the wheels were loose and floppy?
Not really a viable repair due to cost, and throwing good money after bad sort of situation, especially if your machine has a sealed wash tub which doesn't come apart.(welded Tub).
Cost of parts in this case would equal cost of new machine. Also, suspension, motor and heater will all be worn too. That's about the life span of machines these days I'm afraid!
Electrolux... | Answered on Jan 21, 2018
E44 - It means "Door closure sensing circuit faulty".
Replace the circuit board and restart the diagnostic cycle to check further alarm condition.
When the washing programme is started by pressing the START/PAUSE button, the bi-metal PTC (contacts 3-5 on door interlock device, no.3 on electrical diagram) is powered by the triac (DOOR TY) on the PCB: after 2 - 4 seconds, this closes the switch (5-4) which powers the electrical components of the appliance (only if the door is closed). The door interlock prevents aperture of the door while the appliance is in operation.
Microprocessor recognize closure position by sensing circuit connected to J2-1 on electronic board.
At the end of the washing programme, the PCB disconnects the interlock from the power supply, but the door remains locked for 1 to 2 minutes (PTC cooling time).
electrolux-ewf-1030-get-qdylxco5jx0zjejqiwkxkzw5-1-0.jpg Dado
Electrolux... | Answered on Nov 18, 2015
Heating element, washing motor and bearing must be earthed.
Dado
Electrolux... | Answered on Jan 06, 2015
If clothes are still wet this mean there is still water in the drum and the pressure switch is not switch in empty position. The fault should be sought in the draining phase. Could be: drain pump ....
Dado
Electrolux... | Answered on Jan 03, 2015
First remedy fault. E32 fault code usually mean problem with water level in drum respectively to pressure switch.
Incorrect calibration of electronic pressure switch
(electronic pressure switch level different from
0-66mm after initial calibration drain and anti-boiling
pressure switch on "empty")
Could be: Tap closed or mains pressure insufficient; solenoid
valve;hydraulic circuit of pressure switches; pressure
switches; wiring between pressure switch and printig circuit board; main PCB
Dado
You should first remove short circuit and replace destroyed components and after that the appliance should reset itself. If is still not happend there is some other components destroyed including PCB.
Dado
It is still water in drum and pressure switch does't switch to empty position. After several attempt, washing-dryer go to end of program. See problem with drain out water.
Water drain until 1st level pressure switch EMPTY (3 min. timeout) + sequence
Dado
My Electrolux washer always come up with an error code of E60, Why? can any one help
Electrolux... | Answered on Sep 27, 2014
Hello Friend, this is Z. Thank you for allowing me to assist you!
If you are receiving an error code E61 on your Electrolux dryer, it usually means that your dryer is experiencing an issue with the heater relay. A qualified technician would pinpoint the problem by checking the wiring for both open and short circuit across heater relay(s). If the wiring isn't the issue, he/she would need to determine whether the problem rest with the main control board. It really could be a hit or miss calculation in parts so I would personally reach out to an experienced tech that will be able to identify the precise reason. Best regards!
Electrolux... | Answered on Jul 31, 2014
Hi Friend, this is Z. Thank you for allowing me to assist you!
Generally, error code DDO means that the dispenser drawer on your unit may be open. If so, close the drawer and the error code should resolve itself.
If you've double-checked the drawer and it is closed, remove the drawer and examine the magnet. If the magnet is missing or defective, the magnet probably needs replacing.
If the magnet is fine and in place, an experienced technician may need to examine the reed switch or main control board.
Since there are cost differences in parts and accessories, it is always a good idea to have a service tech properly diagnose your appliance.
Electrolux... | Answered on Jul 21, 2014
Good Morning Friend,
I understand your Electrolux washer, model# EWF1087, is making knocking sounds during the spin cycle. In researching your model number, I show that your appliance was manufactured in Australia. If this were manufactured in the U.S., I would suggest making sure that the load was balanced. Balance your wash load and if you are still having trouble, I suggest contacting the manufacturer in Australia. Hope this is helpful.
-Best Regards-
WP
Electrolux... | Answered on Jun 24, 2014
Good Afternoon Friend,
I understand that you are receiving an E=19 error code on your Electrolux washer, model# EW1200i. I have researched your appliance and noticed that it was manufactured in the UK. What is suggested for the North American appliances is to reset them, by either unplugging them or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this. If this does not work, I suggest contacting the manufacturer for further assistance. Hope this is helpful.
-Best Regards-
WP
Electrolux... | Answered on Jun 02, 2014
if the voltage going to the dryer is correct it is probably a bad start capacitor on the motor a bad time will also cause it not to start one more thing can think of on the door there is a door safety switch bypass the door safety switch and see if it will start
Electrolux... | Answered on Jan 29, 2014
Hello Matt, I am happy to assist you!
Generally, error code E21 means that the water in your wash machine is not pumping out fast enough. First, check the drain hose for any restrictions or kinks. If you have check the hose and it appears to be clear and free, then potentially the underlying issue may be the main control board or pump. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
Electrolux... | Answered on Dec 07, 2013
did you happen to solve the problem? I am having the same exact issue with mine...washes fine, but won't do the spin cycle. it spins counter clockwise really slow at first, presumably to balance the clothes, and then starts to spin up clockwise (to do the spin cycle) but then whinnies and then stops....!
Electrolux... | Answered on Dec 06, 2013
Electrolux EW1200i Front Load Washer / Dryer Logo
132 questions posted
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Poppa Maddo
Poppa Maddo
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Electrolux Washing Machines
Most Popular Question
electrolux error code e 19
  • Washing Machines
