SOURCE: Frigidiare upright freezer has just stopped cooling
I was hoping it would be something like a cracked door seal, or a faulty thermostat, etc., but after reading the rest of your info, I've concluded the likely cause is a slow leak in the refridgerant line(s). I've seen many of these fairly new upright freezers with this problem.
Finding the leak is easy for a service tech to find, but the cost of the service tech isn't cheap and unfortunately, the repair cost will probably exceed the cost of a new freezer, but you can try to call a repair tech and see if they can give you a rough estimate over the phone or if they think it's worth fixing, etc.
My advice is to replace it. The cost of food you've lost has probably exceeded the price of a new freezer - and you've had this happen twice now. These days it seems that some appliances are being designed and built as "throw aways" due to the high repair cost.
Wished I had some better news for you, but unless you've got all the specialty tools; (charging gauges, vaccum pump, Freon, etc.) needed to do the repair yourself, along with the technical knowledge, it's likely not worth having the repair service contracted. Best Regards.
SOURCE: stove door wont close
try shutting off power and then turn on..If this doesnt work turn on self clean again ,start it then after a few seconds cancel. This should tell the lock to release.
SOURCE: fridge freezer door won'tstay closed
Faulty door seal.The seal that holds the door has a grip and a magnet on other side.May be that needs to be replaced.Or any fringe section tray is not completely fitted,to its end causing these. Replacement parts can be
purchased at any of the following web sites: partsselect.com -------------------- Before going to buy any parts
directly. This is list of refrigerator problems,
which is normally faced in refrigerator. -------------- ------------ ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html ------------- http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html These will help. Thanks,.
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Go through this troubleshooting help links.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making
ice?
Water Overflows in Ice maker
and freezes inside?
How to replace Ice maker
assembly?
Cut up a
whole watermelon. Take out the seeds and cut off the rind. Use a food processor
to blend the flesh of the watermelon and pour into ice cube trays and freeze.
