20 Most Recent
Frigidaire FRT21H8 Top Freezer Refrigerator Questions & Answers
Refrigerator door pops open, frigidaire top
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
What causes water to pool on the top shelf?
Hello
It is caused by a clogged defrost drain in the freezer compartment of your refrigerator
To fix this you will need to empty your refrigerator and unplug it.
Remove the back panel of the freezer and look under the cooling coil, you will see a frozen drain
pour hot water on the drain hole until water flows freely through the drain to the bottom pan..
That's it
Reversed a door
you should be able to reverse your doors just take bolts out on hinges pop out plugs on oppasite side
I have a frt18drh fridg. every time it comes on I
Good Afternoon frnk, thank you for allowing me to assist
you!
Your new high-efficiency refrigerator may make unfamiliar
sounds. These are all normal sounds and soon will become common to you. This
also indicates your refrigerator is operating as designed. Hard surfaces, such
as vinyl or wood floors, walls, and kitchen cabinets may make sounds more
noticeable. If the noise, however, become louder or more pronounced, then you
may want to connect with a local appliance technician to determine if anything
else may be the cause.
Freezer working, refrigerator not
Hello Georgia Peterson - Do you hear anything running in the machine compartment and what type of airflow is the condenser fan providing (try removing the toe grille, located above the drain pain on the bottom right-hand side)? If you do not hear the compressor and unit is providing room temperature, it usually means that the unit has a faulty compressor or a sealed system leak. Also there is a vent towards the back of the freezer that circulates air from the freezer section to the fresh food section. If this vent is blocked by too many items in the freezer it will cause the unit to work harder making it colder in the freezer and keeps the air from flowing down to the refrigerated section. If you would, make sure that the vent is not blocked so that air can travel from the vent down to the refrigerated part. This will decrease the temperature in the freezer, allowing for ice cream to be pliable and the fresh food section to become colder. Should you find these suggestions unsuccessful I would recommend contacting a professional to move forward accurately.
My fridgedaire fridge FRT856embg wont get cold on the bottom
Im not familure with this item but on the older style fridge ice would build up in the freezer blocking the air ways to the bottom half of the fridge in this case you would need to remove the food from the freezer and fridge and unplug it open the doors and let it thaw out for a day or so I wish you luck and I hope this was helpful
Freezer not staying cold
the temp control thinks its cold enough to stay off so you need to have the temp in home warmer so it will cycle / atleast 60 / larry
