Dishwashers Logo
Posted on Jun 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Very long cycle times, hours instead of minutes. All cycles work and the knob does move, just very slow.
Gerald Griffin
Level 2:
  • Expert 248 Answers
  • Posted on Jun 11, 2010
Gerald Griffin
Expert
Level 2:
Answers
248
Questions
0
Helped
148429
Points
570
Many dishwashers now days can take 120 minutes to complete cycles.
True GDM-10 started making loud noise AFTER door was slammed after getting something inside; checked inside fan was running slow. Noise sound like something stuck in motor.
without knowing age of unit, I suggest replacing the motor. Sounds like the armature is worn the bearings and is moving inside the windings of the motor. I would do that first before moving forward with any other repairs.
My GE washer is stuck on a Stain cycle and it will not start. I can change the cycle, but it will not start and if I turn power off and on again, it goes back to Stain cycle. We've held the start/pause...
the G.E IS USUALLY RESET BY UNPLIGGING THE MACHINE A COUPLE MINUTES THEN PLUG IT BACK AND TURN THE ON KNOB TO ON THEN PULL OUT . THEN OPEN AND CLOSE THE LID SLIGHTLY) NOT ALL THE WAY JUST SLIGHTLY ) 6 TIMES WITHIN A 12 SECOND PERIOD , THIS SHOULD RESET THE WASHER IF IT DOESNT WORK THEN TRY THE SAME WITH THE KNOB ON THE OFF POSITION PUSHED IN
Timer that has a 20 minutes interval up to 1 hour
More information is needed.
For example, a) what voltage timer is needed, b) what Load are you controlling and c) how does timer mount?
Easiest solution is 60 minute repeat cycle timer.
Timer knobs are adjusted, or the timer dial rotates once per hour and 20 minute timing cycle repeats each hour. The cycle repeats 24-7-365.
If you want the cycle to operate certain hours of the day, another 24 hour timer can be installed in-line.
1) Tork 8600 cycle timer, or Tork ACT percent cycle timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#8000
https://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hbZ1z0q55s
-or-
2) Intermatic CT2000 percent cycle timer, C8800 cycle timer
http://waterheatertimer.org/pdf/025-Talento-121-cycle-timer.pdf
-or-
3) For din-rail mount, Intermatic Talento 121 cycle timer
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
Add a comment
How to set times
You posted under Tork 8000 series cycling timer
Open following link to identify timer for sure and download wiring and instruction manuals.
Cycling timers have built-in trippers (or tabs) located on outer edge of dial
Lift each tripper up and rotate it toward center of dial to set on-off times.
The dial rotates as time passes, and the trippers move lever that turns load on-off.
For example if you have 8601 timer, the dial cycles every 60 minutes or once per hour.
Each tripper represents 1 minute.
So if you want NO terminals turned ON for 2 minutes each hour, then move 2 successive trippers up.
If you want NC terminals turned ON for 58 minutes, then leave 58 successive trippers down.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
My Kenmore Washing Machine Model 110.82872100 goes through the wash cycle then gets to rinse cycle fills with water makes a clicking noise and stops. Does not drain but cycle knob moves. An electrical...
Your motor is getting overheated in wash cycle. if you turn it off for about 15 minutes and start it back up in rinse cycle will it work ? If yes, then motor is overheated. A sign that the motor is over working its self and time for a new motor.
Cycle takes 3 hours instead of 30 minutes
You timer is bad and needs to be replaced. It is located behind the control board
Spin cycle lasts indefinately
the spin cylce in washer, did not shut off?soundslike an issue with the timer itself, no servicing htetimer strictly replace, as far as teh time in the dryer, i would check for clogged/kinked dryer vent, biggest issue with any dryer, innadequate vent
KITCH AID DRYER
It sounds like the timer motor isn't advancing. You will have to replace the timer.
17helpful
Coffee brews and then immediately shuts off Cuisinart DCC-1200
To program the Variable Auto Off: 1. Turn the FUNCTION KNOB to the ?Auto Off? position. Press and hold the ?Hour? button for 2 seconds. The clock display will start blinking. 2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the ?Hour? and ?Minute? push-buttons. (see ?To set the time?)
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
