20 Most Recent Whirlpool GGQ8831L Gas Dryer Questions & Answers
Whirlpool ultimate care ii dryer. Drying a load
this has gas coils on top of the gas valve the flame might ignite for the first 10 to 15 minutes but if the coils are failing you won't have any flame after they heat up,when they cool down they will work again so i would say you have bad gas coils,easy fix,remove the two phillips screws,remove the top cover,remove the connectors off of the coils and reinstall the new coils,watch out for the large coil,there's a spacer that slides onto the post,if it's not there poke it out of the old coil and slide it back on the post and then slide the large coil onto the post,i've gone in and found this missing on some dryers that the customer had changed out the coils themselves before,it will still work but it can chatter alot.also while your in there remove the thermal fuse and the cycling t-stat both on the blower wheel housing and make sure there's no lint buildup on the back of them,if so just clean them off and you'll be fine
12/3/2017 2:38:21 AM • Whirlpool... • Answered on Dec 03, 2017
2answers
Dryer trips the GFI
It sounds as though some component in the dryer has a high resistance short to ground. Not enough to burn it up, but enough to allow the current in the hot leg of 120VAC to be greater than the current through the neutral leg.
It is also possible that the ground is a low resistance short to ground. Have you tried to temporarily plug the dryer into a non GFI outlet (use a heavy duty extension cord)? If so, does the breaker for that circuit trip?
DO NOT LEAVE THE APPLIANCE CONNECTED USING AN EXTENSION CORD! THIS IS ONLY TO TEST THE APPLICANCE FOR A HIGH RESISTANCE SHORT.
Either way, I would be suspect of the motor first, and the pilot igniter circuit 2nd. Please provide more information as to what you find in the test above.
8/10/2016 10:09:09 PM • Whirlpool... • Answered on Aug 10, 2016
My tromm dle 7177 is blowing cold air and the check filter light stays on
Also check the vent. It is trying to tell you there is no air flow.
2/4/2014 11:25:25 AM • Whirlpool... • Answered on Feb 04, 2014
0answers
Where do you look for the igniter
Most of the igniters are located in the lower front area of the dryer. You need to remove the top cover from the front area , using a spatula to Pop it open (don't forget to remove the filter if its located on the top, Including the two screws that hold the base) . Then you need to remove the front plate by removing two screws from the inside upper Area . The igniter is a ceramic fuse that will click and glow completely Red and ready for the gas to create the flame and heat for you dryer. If you model has a bottom front cover only and after you remove it ,then it will be easier to observe The actual process of the igniter if it is working properly . Good luck
11/5/2013 5:41:54 AM • Whirlpool... • Answered on Nov 05, 2013
Whirlpool gas dryer lg7681 heat
There are several thermal safety fuses in dryers which once blown have to be replaced. But, more importantly, they normally blow for a reason and simply replacing one without resolving the underlying problem of overheating will simply cause another failure. Lint is the normal culprit; vacuum and forced air to clean everything out. WITH THE POWER CORD UNPLUGGED and the leads temporarily disconnected, check continuity on each of the thermal fuses (they look like a stainless steel hat that might fit on a Barbie doll. Some dryers have four or five.).
9/11/2013 1:32:37 AM • Whirlpool... • Answered on Sep 11, 2013
6answers
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
5/2/2013 2:12:22 AM • Whirlpool... • Answered on May 02, 2013
My whirlpool gas dryer, it has only a cool air what should I do? I need a hot air, please help me.
Take a look at this video. It will walk you thru the troubleshooting process.
10/23/2012 3:27:11 PM • Whirlpool... • Answered on Oct 23, 2012
3answers
1 yr old gas Whirpool dryer...
So if the motor doesnt start is just buzzing, The windings have gone out in the motor. You have to replace the whole motor. If you get me the model number i can get you a part number and you can order the part from sears.
4/22/2012 3:08:56 AM • Whirlpool... • Answered on Apr 22, 2012
Can I use a lint
Yes and no....
Do not place the kit immediately off of the dryer...give it at least a few feet of space from the dryer to the kit to let it cool down a bit before getting to the kit.
Make sure to check it often and keep the hose and the kit clean....if it clogs up it will cause things inside the dryer to go bad...
Take a bit of care and install it properly, keep it clean and you will be happy with it.
heatman101
9/5/2011 11:14:53 AM • Whirlpool... • Answered on Sep 05, 2011
Whirlpool # leq8000jq4 has
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101=-
8/14/2011 3:46:16 AM • Whirlpool... • Answered on Aug 14, 2011
I have a gas dryer and it will not heat. It did
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
3/18/2011 5:48:40 PM • Whirlpool... • Answered on Mar 18, 2011
Had no heat. replaced thermostat, heat returned
this website will help, more then likely you will need to clean the venting system and replace all the recommended parts for your dryer:
http://www.applianceaid.com/gas_dryer.html#noheat
2/27/2011 1:46:52 AM • Whirlpool... • Answered on Feb 27, 2011
I have an older Whirlpool
Hello & Welcome to FixYa
The loud noise that you hear is from the belt that is either broken or worn out, you can check this picture....part#30 is the belt that needs replacement. Also check the idler pulley (part#13) and motor pulley (part#29). Please get back to me if you have any other questions.
Kevin
2/7/2011 10:15:00 PM • Whirlpool... • Answered on Feb 07, 2011
No heat in maytag neptune electric dryer
heatman101
2/5/2011 4:57:21 AM • Whirlpool... • Answered on Feb 05, 2011
No heat
heatman101
1/15/2011 3:50:12 AM • Whirlpool... • Answered on Jan 15, 2011
Whirlpool GGQ8831L Gas Dryer Logo
166 questions posted
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
use lint
  • Dryers
