20 Most Recent
GE 24 in. Profile PDW7800 Built-in Dishwasher Questions & Answers
GE Externa Tritan XL (7 yrs old): Standing dirty water
Hello, there isnt much that you can do, there could be a number of problems. It could be a slight blockage somewhere from your drainage hoses to your pump. It could also not be spinning properly. If you want to drain the rest of the water out you will need to get your drainage hose and lay it flat on the floor to a drain, this will stop things getting smelly. You just may have to get a repair man in, I hope this helps.
11/8/2018 6:01:11 PM •
GE 24 in....
Answered
on Nov 08, 2018
Diswasher circuit connect problem
Sounds like you might have done something wrong or disturbed the control panel to the wiring......I don't think that there's any other answer.
12/17/2017 7:17:22 PM •
GE 24 in....
Answered
on Dec 17, 2017
Ge profile dishwasher not cleaning
Our GE dishwasher never did clean correctly. Then it died. WE bought a new dishwasher different brand . New dishwasher is cleaning great clean dishes now. GE Dishwashers sucks!
4/24/2016 12:46:17 AM •
GE 24 in....
Answered
on Apr 24, 2016
Middle arm of dishwasher not spinning
I'm the one that reported the same problem in November as "Guest". I fixed mine finally. I removed the middle arm again and noticed that the holes that spray a jet ot water causing the arm to turn aren't the ones on top. On the bottom of the arm there's a small hole at each end. I looked and one of the holes had a small piece of crud in it. I had to use the tip of an ice pick to dislodge it back into the arm. I then ran water into the arm several times hoping to get the item completely removed. I never did see anything come out but I then ran water through the arm holding it so the water could run out one end. The piece didn't show up in the hole again so I tried washing it to the other end. It still didn't show up so I guess it must have washed out the first time. It's been 3 or 4 weeks now and the arm is still functioning perfectly. Hard to believe that one little piece of trash can cause so much irritation. Good luck on this being the problem for others.
2/17/2016 6:19:39 PM •
GE 24 in....
Answered
on Feb 17, 2016
I have a ge profile
I'm having the same problem with my GE PDW7800's touchpad. the buttons to the right of the Start button are dying. I'm now having to play a dance between with the "button lock" mode and Time Delay to get it started. Unfortunately, the capacitive touch panels are delicate and have a limited lifespan. You're looking at replacing the touchpad, or buying a new dishwasher
I'll be replacing mine eventually, but the lowest price I've seen is currently $230, so this is a fairly expensive repair. (That is why I've not replaced it yet. I can play the button dance game a little longer, but eventually it will cease to function at all.)
2/1/2015 1:58:57 AM •
GE 24 in....
Answered
on Feb 01, 2015
