Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
Posted on Dec 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon busy signal busy signal after take a picture
Anonymous
Level 3:
  • Master 2,335 Answers
  • Posted on Apr 15, 2010
Anonymous
Master
Level 3:
Answers
2335
Questions
0
Helped
882809
Points
4663
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
3 Related Answers
Anonymous
  • 37 Answers
  • Posted on Jul 17, 2009
SOURCE: Busy message when trying to take picture with
Busy usually means the camera is writing to the card. Have you tried to format the card in the camera and then take pictures?
Anonymous
  • 11967 Answers
  • Posted on Dec 19, 2009
SOURCE: Canon Rebel XS displays busy signal after I take a
Is your card nearly full? Is your battery fully charged?
Anonymous
  • Posted on Jan 29, 2011
SOURCE: i have a canon rebel
Not sure, a couple things to check are the memory card you are using. If you have different card give it a try. Also, if you are trying to do burst mode there is a limit for your camera depending upon your settings. When you reach that limit the camera has to wait while all the data is written to the memory card.
1helpful
I have a canon rebel xti, when I take several pictures a get a busy signal and have to wait before I take another picture (flash?) how do i take pictures, many in a row without getting a busy signal..as if...
How to transfer picture from the camera to a computer with a busy
have you try to remove your memory card
and put directly in the pc memory card hole then clear your card and formated if it not works its could be the driver sofware or the card it self ...
thats something like that just verify this and you will no....because company make change in firware version to fit with with vista or win 7!..
i hope that will help you /and you have canon wed sit
under customer/support/service
2helpful
A hand signal with a line through it appears and says Busy, after we shoot a picture using a Canon Power Shot SX200
The signal is an alert that the camera is storing the images just stored.i.e processing the last action.
2helpful
2answers
2helpful
Canon XSI showing "busy" when taking multiple shots
It can be that your batteries are low and takes longer to charge the flash... It can also be that your memory card is a slow on. If the red processing light on the back of the camera is staying on a long time, it means the camera is having trouble feeding the picture to the card... You might try decreasing the picture quality a little...
Flash busy signal
This is perfectly normal, the flash uses short burst of electricity that are stored in a large state capacitor. This has to be recharged after so many pictures. You can go as fast as the SD card will allow even if the flash is charging, simply close the flash and continue taking photos without it, no effect apart from loss of some illumination depending on the conditions.
Busy signal while taking a picture
Have you been taking shots in continuous mode (burst)?  The camera has a built in buffer of fast memory where photos are stored before being written to the slower CF card.  Once the memory gets full the camera will not take another picture unless some of the images complete transfer to the CF card. You will notice a number inside your viewfinder (bottom left) the number goes down when you take a picture that is how much space is left in the buffer when it hits 0 the buffer is full it will go up as the buffer clears.  Note that RAW takes up more space and fills the buffer quickly.
If you get the "Busy" message even after just 1 shot then there is something wrong with either your CF card or your camera and you should take try another card or it to canon for service.
Pictures will not download
Remove batteries for an hours or so Then replace[with fresh or recharged if you can] and see if the camera has recovered. If it still is not good Canon customer support is th next place to go.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
