20 Most Recent Canon EOS 5D Mark II Digital Camera Questions & Answers
Frequent error 80 occursdespite using different
That error is really only a very generic error "Err 80 Malfunctions related to the electric control or images have been detected." -Turn the power switch to OFf then to ON; to turn on the power again. -Remove and re-install the battery. Clean the area where the lens meets the body with a pencil eraser. Hope this helps, good luck.
11/18/2017 2:33:31 PM • Canon EOS 5D... • Answered on Nov 18, 2017
Hi, i have a canon
Most definitely battery grip. Prone to a phenomenon know as 'flexing'. The contacts on the grip fail to connect to camera's contacts. Can cause other problems such as switching on and off when you least expect it. I got sick of going thru about two grips for every camera so went with 1D/1Ds series. You'll hear people say 'stick with Canon grips' blahhh(!) too ****** expensive and are prone to the same problem. Can't be helped when you hand hold a camera+grip for long periods - the warmth of your hands can heat up (warp) the plastics and it's all held 'together' by one little screw in a tripod mount (!)
You could 'try' removing the grip, leave it off for say a week. I don't know why it's how, but if always works like new when you put it on again. Until....it starts playing up again. :)
OEM, 3RD party... OTY. For the price of one Canon I could get two cheapies. Always had the 1D (classic) and ahem...still have it! So I stuck with the series (1D IV, 1Ds2) Still holding onto my 7D w/grip (3rd party) though.
10/28/2017 10:04:09 PM • Canon EOS 5D... • Answered on Oct 28, 2017
My Canon 5D Mark II images appear almost black. It doesn't matter which setting it is on. How to fix the problem? I have used the camera for several years & this is a new problem. Any suggestions?
If this happens with different lenses then I think you've got a repair job on your hand. If it only happens with one particular lens then it may be the lens.
2/2/2017 11:36:04 PM • Canon EOS 5D... • Answered on Feb 02, 2017
Pink cast on whites canon 5d mark 2
This could be to do with the type of lights you are using and not the camera.
9/2/2016 10:12:37 PM • Canon EOS 5D... • Answered on Sep 02, 2016
Canon 5D Mark II error 80
Error Code 80 on the 5D II indicates the a Malfunction related to the electric control of images has been detected.
9/2/2016 10:08:10 PM • Canon EOS 5D... • Answered on Sep 02, 2016
My camera will not power up when switched on. The batteries are fully charged and I cleaned the terminals. The battery compartment is also closed. What else could I check myself?
Switch off, remove batt, then replace the bat. You should notice a red LED blink. If that does not blink, you can't do much yourself. Take it in for a proper check by authorized service tech.
10/28/2015 1:21:33 AM • Canon EOS 5D... • Answered on Oct 28, 2015
Service manual
You need proprietary software to work on this model
1/4/2015 3:27:34 AM • Canon EOS 5D... • Answered on Jan 04, 2015
When I look thru the viewfinder, I now have a small circle view - about the size of a quarter coin- no matter what lens I use. I took lens off, looked at mirrors which seem OK. I released and depresse
Sounds like the focus screen is missing. There is a frame that holds it in and also a rectangular brass spacer behind it. You would have to send it to Canon as the spacer comes in about 7 depths and has to match for proper focus.
11/26/2014 12:56:29 AM • Canon EOS 5D... • Answered on Nov 26, 2014
Cannon EOS 5d mark 3....it is in another
I was able to download the manual from Canon USA for free. I could search the page for you, but perhaps you also want the manual and read it yourself? here is the link to the download page: EOS 5D Mark III
11/20/2014 7:35:37 PM • Canon EOS 5D... • Answered on Nov 20, 2014
How to turn off self time Canon EOS5 D
Change the drive mode to single shot
9/4/2014 2:38:26 PM • Canon EOS 5D... • Answered on Sep 04, 2014
My MK2 will not change the iso when in video mode
Have you tried to put the exposure mode to "manual"? If you leave it in automatic exposure mode, the iso, speed and aperture will always combine themselves to give the correct exposure and therefore will not let you overexpose your video. Hope this will help.
3/24/2014 8:42:35 PM • Canon EOS 5D... • Answered on Mar 24, 2014
Can't set self timer on 5d
Your mode dial may be set on a function that does not support self timer. Turn you mode dial to P and see if it operates then
3/10/2014 9:13:00 PM • Canon EOS 5D... • Answered on Mar 10, 2014
Error code 80 + lock up functions
Still, when this error comes back, you should contact Canon. On of the options hinting, you should use Canon lenses. So perhaps one of the contacts is a bit dirty? Try cleaning all contacts in your camera, involved with lens and battery connection. Sometimes changing a lens can have a cleaning effect to. Most of the time not forever. Success
1/20/2014 2:01:16 PM • Canon EOS 5D... • Answered on Jan 20, 2014
5d mark II working without memory card ,but with
I have seen this problem some times. Usually it comes from a fail at the CF PCB (compact flash printed circuit bard) and it is necessary to change the board. Sometimes the problem is the "bent pin syndrome" that frecuently occurs by using cheap Flash Cards.
10/29/2013 3:32:27 AM • Canon EOS 5D... • Answered on Oct 29, 2013
Memory card release button broken
The card release assembly is located on the back of the rear main circuit board. This is not a repair I would recommend to someone who is not used to dealing with static sensitive circuits and does not have an anti-static setup for repair
10/27/2013 2:44:21 AM • Canon EOS 5D... • Answered on Oct 27, 2013
Memory card folder changed from EOS to EKS
Have you tried formatting the card in camera? Always format cards in camera, don't just delete all photos.If that doesn't work, format the card on the computer in FAT32 and then format in the camera.
10/25/2013 5:50:56 AM • Canon EOS 5D... • Answered on Oct 25, 2013
The language on my Canon EOS 5D Mark III is all in
The solution popped up from fixya before i could type anything. look above
10/21/2013 3:38:30 AM • Canon EOS 5D... • Answered on Oct 21, 2013
When i take a picture, it either pops up sensor
Sensor clean is triggered when the camera powers off and on. It sounds like the lens mounts are dirty or damaged and on a camera that pricey, go see a specialist!
10/15/2013 6:32:21 PM • Canon EOS 5D... • Answered on Oct 15, 2013
When i look through the view finder to take a pic theres a tunnel vision effect and i cant see the full view
sounds like your focus screen fell out
3/7/2013 3:16:38 AM • Canon EOS 5D... • Answered on Mar 07, 2013
Red tint on my 5D cannnon camera pictures
Tony, This is either a circuit board fault or faulty censor assembly that is going to require camera shop repair. this is not a user fix problem.
1/26/2013 2:18:42 AM • Canon EOS 5D... • Answered on Jan 26, 2013
Canon EOS 5D Mark II Digital Camera Logo
51 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Eos Canon
  • Eos Canon
Most Popular Question
when picture either pops up sensor
  • Cameras
