20 Most Recent Canon EOS Rebel XS 35mm SLR Camera Questions & Answers
You didn't say which shooting mode you're using, but I'd bet you're in Manual mode and have dialed in a completely wrong aperture/shutter speed combination for bright lighting conditions. For example, 1/60th of a second and f2.8 in bright sunlight would be "burning out" your image, so the camera may be giving you an error message. Try using AUTO or PROG setting and see if the problem persists. If it does, try a different lens. You may have an incompatible mount, or one of the contacts may be damaged. If all else fails, try your lens on another Canon camera.
Canon EOS Rebel... | Answered on Oct 06, 2017
I don't have any ideas on why the camera is not shooting, but you can view or download the instruction manual here.
Canon EOS Rebel... | Answered on Dec 30, 2016
Format the memory card in the camera, not the computer. Also, it could be a memory card issue, do other cards cause the camera to return the same message. If yes, then it well could be the camera.
Canon EOS Rebel... | Answered on Nov 28, 2016
If your lens is a EF mount and your digital can take EF lens the answer is yes.
Cordially,
Canon EOS Rebel... | Answered on Feb 02, 2015
You did not mention which lens. Some Canon digital cameras will only take EFS lens, others take both EF and EFS. Also there are other types of lens mounts made by Canon.
Cordially,
Sorry not at all understanding your comment, does not appear to be a question. Here is my best guess for an answer, Always format in camera.
sorry, you have not provided enough information. So, here is a simple answer, hold the camera so that the long side is parallel to the ground, that is landscape mode. Portrait mode is the short side parallel with the ground, thus rotate the camera 90 degrees.
All cameras work the same way, it is the position we the shooter holds the camera.
Cordially
Canon EOS Rebel XS 35mm SLR Camera Logo
126 questions posted
Top Canon Photography Experts
old marine
old marine
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Canon Photography Expert? Answer questions, earn points and help others
View Most Popular
Canon Photography
  • Canon Photography
Most Popular Question
camera not display picture prior taking
  • Photography
