20 Most Recent
Canon EOS 400D / Rebel XTi Digital Camera with 18-55mm Lens Questions & Answers
Camera won't turn on
check for corrosion on your battery's contacts. If that's OK try operating your camera with the lense off.
If succeeded, you should try and fix your lense (do check if your camera wasn't damaged by it too).
Cannot transfer images from my Canon DSLR XTi to my computer
Having same issue as above - I thought it was my cable so I ordered a new one. The camera attempts to 'speak' to the pc - and then the Windows box pops up not recognising the USB installed device....I also uninstalled and reloaded the Canon software (had camera for 18 months and only started this rubbish a month back) - was about to re-laod my entire PC - thankfully I saw it was not only me.
Will send mine in for a Firmware update / service.
Rebel T2i won't power on
I had this problem and thank you to the gent that suggested there was a battery compartment closing detection mechanism. I have a battery grip and had removed that to register my t2i (needed the serial number on the bottom) and never checked operation after replacing. I toyed with the lever using a pen and noticed the red light flicker. I replaced the battery grip with batteries and all is well.
Sometimes we need a nudge to dig deeper... I had looked at the possibility of a door closed switch much the same as the the switch on the sd card door. I took a second look and found it. Thanks a million for jogging my analytical brain!
Canon 400D
Use a card writer and copy your pictures to the CF card on the computer.
Built-in flash does not fire off
Not really a solution, and about 3 years late :) my EOS400D also developed the same problem (however it was also coincidence that I had just updated to Firmware 1.1.1 (from 1.0.4), but basically the flash would pop up, but wouldn't fire (so not the standard problem with the microswitches), I found with a bit of forum searching that if you hold the flash down to almost clicking it in and then shoot it does actually fire. I am going to see how much it costs to get this fixed and will post what the actual fault is if I can understand the repairman.
Xti wont power up
appears to be a defect and not user serviceable.
sorry for the news.
good luck.
mark.
My canon 400d, suddenly stopped working, it does
Such symptom indicate a malfunction on the DC/DC voltage converter circuitry, and the camera has two of them located in different boards.
In order to perform a correct diagnostics and repair of it, it is necessary to open such camera and perform it by a qualified camera repair technician.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you hav the options of pay for its repair, or do it yourself if you are willing tgo open it and perform some basic diagnostics of the failure. You will needtools to do it, which includes the usage of a soldering iron.
Best regards,
EOS 500d err 05 a clicking noise then a message saying my flash will not work in this mode
This is usually caused by impact or sticky liquid spillage on the flash causing it to stick down. Lift up on the flash head when it clicks to free it and then used a Qtip soaked in water or Windex to clean around the flash. You may have to disassemble the flash and clean the pivots -especially the pivot screw if rusted (scape off the rust with a Xacto blade and then lightly coat with grease)
Lost solution disk and directional manual disk need downloads
You don't need any special software to use your camera.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program, such as
Picsaa.
When the camera is in auto mode, the busy sign
SD cards come in different levels. If you look at your card there should be a number on the front of the card. the higher the number means the faster the card. If you have a level 6 card then you shouldn't have the problem of getting a busy signal. your photos are large files and if your card is slow ie a level 3 then it takes time for the data to copy to it. So find yourself a level 5 or 6 card and you shouldn't have this problem.
I have a Canon Rebel
Sorry to hear about this. I have a similar camera and have been racking my brain about this...
My only thought...are you using the same battery charger? Perhaps the battery charger is to blame. You may be out of battery on both batteries. When you install the battery, does ANYTHING happen? Does it say, LOW Battery or CHANGE the battery? Or is it totally black? If nothing happens at all, you should probably contact Canon directly. Or purchase a new charger and see if that fixes the problem.
Canon Customer Support Center
Phone:
1-800-OK-CANON
1-800-652-2666
Hope this helps!
Canon 400D,Error 99 keeps coming up,have replaced
Welcome to Fixya
Err 99 could means several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Have a good one! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Err 99 on a 400d how can it b fixed
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon. If you need further help, reach me via phone at
