20 Most Recent
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Questions & Answers
Canon EOS Rebel XS - won't turn on, unless I
Hi.
Test using a different battery. When it does like that it is often the battery shorted inside. If the problem occurs using a known-good battery, then the contacts in the battery slots or the circuits behind the contacts have a short. When there is no battery the shorted wires or contacts are not "hot" and the short does not prevent the camera from starting.
If the problem is not the battery the camera must be disassembled. In that case disassembling will start from the screws on right hand side (watching from front), then screws in front, then left and back. Unless you have done similar repairs before it is advisable not attempting to disassemble the camera. The camera is very easy to damage. There are springs, wires and tricky parts near to shutter button on top, selector wheel and strap holder. If problem is camera and not the battery you can get a good quote on repair here:
Repair.Regards.
Ginko
10/10/2019 6:21:15 AM •
Canon EOS...
Answered
on Oct 10, 2019
I have a new Rebel xs kit, and after 20 shots, I
I can help you fix the
BUSY Error or
Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
- Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
- The message, "Err 99 Shooting is not
possible. Turn the power switch to<OFF> and <ON> again or
re-install the battery", appears on the camera's LCD monitor, and after
the above operation is carried out,the LCD monitor displays in a
language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these
Fixya Tips :
- Follow this link to download a pdf version of the firmware installation instruction guide.
- Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
- Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
- Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
12/1/2018 6:04:45 PM •
Canon EOS...
Answered
on Dec 01, 2018
Codee error 99 ??
hi,
I do not know if this is going to be of any help. I was actually reading about this error code 99 in canon, and bumped into a forum, where people had share their experiences. You can give it a try. But if your camera is still under warranty, it is best to ring technical support.
"ERR 99" is a general error code displayed by the camera when the camera knows that something is not working properly, but not exactly what.
This error is typically associated with lens communication or shutter mechanism issues. To isolate the cause of the issue, we suggest that
you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the "ERR 99" message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
Hope this helps !!!
12/1/2018 6:02:48 PM •
Canon EOS...
Answered
on Dec 01, 2018
Greetings!!
I hope you are doing
Thank you for your sunshine. This is not the kind of query with which Fixya can really assist you, I'm afraid - have you thought of consulting the many on-line forums which exist to offer advice on exposure and software. Good luck.
12/1/2018 11:44:53 AM •
Canon EOS...
Answered
on Dec 01, 2018
My canon EOS 100D digital
Card was removed before the camera was completely shut down or whilst software was being updated. Camera is 'bricked' will need to be sent to canon service agents for repairs.
9/24/2017 5:36:13 PM •
Canon EOS...
Answered
on Sep 24, 2017
My canon rebel
press menu 5th menu along select item 1 up from bottom (live view function setting), select enable then quit menu press set button to activate live view
9/2/2016 9:57:09 PM •
Canon EOS...
Answered
on Sep 02, 2016
How do i save raw pictures from my camera to a
You can't burn raw pictures. They are only data from a camera....not an actual picture. They must be processed in an editing program and then converted to another format such as jpeg or tiff.
11/4/2015 5:01:29 PM •
Canon EOS...
Answered
on Nov 04, 2015
Error code 99. Please tellme what this means.
This is what the people at the canon tech support say to do for error 99
read this!! :)
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked
hope this works for you!!!! have a nice day!! :) :)
10/29/2015 3:42:09 AM •
Canon EOS...
Answered
on Oct 29, 2015
My Canon 1000D won't operate even when turned on.
BUSY Error or
Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
Fixya Tips :
I hope that helps.
3/2/2015 7:03:21 PM •
Canon EOS...
Answered
on Mar 02, 2015
Card cannot create folder
Are you trying to create a folder in the camera or on a computer. If in the camera it should create a folder for the date you are shooting automatically. Rich
12/27/2014 7:14:10 PM •
Canon EOS...
Answered
on Dec 27, 2014
When I try to download images direct to computer...FAILED TO INITALIZE PROGRAMM appears and the flashing blue light does not come on
What program are you using?
You might want to consider NOT connecting your camera to your computer. The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
12/17/2014 8:39:23 PM •
Canon EOS...
Answered
on Dec 17, 2014
Can't transfer pictures from canon EOS 100D camera to computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
11/21/2014 3:59:26 PM •
Canon EOS...
Answered
on Nov 21, 2014
