E-Machines eMachines Desktop PC Logo
Posted on Nov 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power Button wire to mother board power led power sw HDD Led . what pin connects to the three wires from power button. Led Power wire to what pins, HDD Led to what pins and power SW to what pins on the mothe board.
Anonymous
Level 2:
  • Expert 255 Answers
  • Posted on Nov 25, 2009
Anonymous
Expert
Level 2:
Answers
255
Questions
0
Helped
129443
Points
807
There are may motherboards, but most have writing on them as to what is suppose to plug where. For example, for the power switch, the lettering might be "Pwr" or "Power" or "Pwr sw". The pins are usually together and should fit the plug on the end of the wire.
1helpful
Where doe's power led,power sw,hdd led on my e-machine
You will need the user's manual for your machine to make sure that you are hooking the wires up correctly. However, most motherboards label these connections directly on the motherboard next to their pins.
Look for an area on the mother motherboard with two rows of six to eight pins. Next to them you should labels such as PWR_SW (power switch), RST_SW (reset switch), HDD_LED, PWR_LED, etc. You won't mess anything up connecting something to the wrong pins, but it isn't that hard to figure out as the wires are usually labeled in the same manner as the pins. So HDD_LED would plug into the HDD_LED pins, PWR_SW to PWR_SW, etc.
2answers
I have a hp pavilion a1777c desktop. i had to take it apart to replace hdd and dvd rom and some other parts. i have been trying to get detailed info on where the front power panel wires connect onto the...
There is usually a set of pins on the corner that are labeled get a magnify glass and light up the board take the glass and look down on one of the corners it is usually on the right corner of the bottom of the board at the bottom of the desktop case. You will usually see a series of abbreviations. LED, HDD, PWR, RES or RE the pins are marked. Now on the wires to the power button you will see the same wire abbreviations. Just hook up the HDD wire to the HDD pin the PWR to the PWR button wire and so on. RESET wire is RE or RES etc. Those really are the only three you will need. Not sure of the exact abbreviations. But they are lettered enough for you to match them. The best thing to do is try to download the board specs and get a look at the pins one side is neg and the other is positive it would be to your best interest to find the mother board specs for you mother board since you went all over the internet and could not find the board specs. just match the LED and the others they are marked PWR is the main and HDD is just showing when the HDD is working. The reset is for the button to reset the computer. It is basic and not that complicated really. Thanks for using FixYa! John
5helpful
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
5helpful
T6410 EMACHINE TRYING TO CONNECT START BUTTON
The motherboard in your computer is an MSI MS-7145, which is also called RS480M. You can download a copy of the manual here. The front panel connections are on page 2-20.
Looking at the header JFP1, pins 1 through 9 (odd numbers) are the front row, pins 2 through 10 are the back. Pin 10 is the missing pin. The power switch connects to pins 6 and 8. The power LED connects to pins 2 and 4. The HDD LED connects to pins 1 and 3. The reset button, if used, connects to pins 5 and 7.
Need to know where LED wires connect on Foxconn mother board.
You can try going to the following site and download the user manual for the motherboard , which would give you the detailed diagram of which cables to connect where
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=661FX4MR-ES&TypeID=en-us0000001
Thanks
proton
How to connet front panel LED & power button
lok at the wire ends they are labled hdd and pwr sw and so om then use magnifyimg glass to look at mobo it will be labled nextto each set of pins to match the wires just plug them in
1helpful
2answers
NEED POWER SWITCH WIRING FOR A EMACHINE T-3095
check on the motherboard there should be a small prints on it near control panel.
Wire came loose on pavilion xe 734 that supplie power to hard dir
First of all these wires don't supply power to HDD. These wires are for indicator LEDs on the front
panel of the cabinet. One wire `power sw' is to switch on the system from the power button on front panel. `power led' wire is of the power led on the front panel. All these wires will be connected to the cluster of pins on one corner of the mother board. If you can see it will be indicated & printed near the cluster of pins on the mbd, that which pair of pins is meant for what connector. Try to correlate the names on connector with the print on the mbd.
3answers
I have a e-machine. Model w3619 a friend sold to me. He unplugged the two power leads that lead from the power button on the front panel from the motherboard.Where do i reconnect them?
The correct wiring plan for this computer is as follows:
Pwr Led Pwr Sw N/C
X X X X O
X X X X X
HDD Rst N/C
Note : N/C = no connection, top row has no pin, bottom row has a pin but not connected.
when you plug in the Pwr Led and HDD connectors, a light should come on, if it doesn't , turn off the pc and turn the connector round on the pins, re -power on your pc.
2helpful
3answers
How to connect the led wires in motherboard
hi use the motherboard manual for this and find front panal connector on motherboard
pin no. 1,3 is for hdd dark color wire is 1 anothee is 3 (hd)
pin no. 2,4 is for power led dark color wire is 2 another is 4 (p_led)
pin no. 5,7 is reset you can connect both side (rst)
pin no. 6,8 is for power on power sw (psw)
most of motherboard folow this diagram
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
