20 Most Recent E-Machines (308714) Motherboard Questions & Answers
on the front panel next to the power pins
E-Machines... | Answered on Apr 03, 2014
Hello the manual can be found here:
http://support.gateway.com/us/en/emac/product/default.aspx
By selecting desktop, and the pc`s model number. (not the mainboard number)
Adobe reader is needed, to read the content.
The front panel connections, look like this:
http://support.gateway.com/emachines/MOTHERBD/Shared/4006232R/4006232Rmvr20.shtml
But i recommend to look in the manual.
Hope this will help you.
E-Machines... | Answered on Jan 27, 2013
inside the tower/case, its the big square circuit board that everything else connects to .....
E-Machines... | Answered on Jan 10, 2013
When you boot up to the log in screen type in administrator as user if you cant log in
During the boot up process you will see on the screen for a short amount of time a certain key to enter set up press and hold that key to enter set up BIOS scroll to set user password or supervisor password you can change or remove the password from there if you are still unable to change your password you might download
http://download.cnet.com/%7Bvalue=http://www.download.com/ubcd4win/3000-2086_4-10550208.html
UBCD4Win is a bootable "live" CD which contains software that allows you to change paswords repair/restore/diagnostic almost any computer problem also has a bios reset tool which remove your password and BIOS password although you will have to use a computer with an internet connection you will have to burn it to a disk as an iso then change your firtst boot device to cd During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed the password you must go back and change the first boot device to your hard drive)
Hope this helps
E-Machines... | Answered on May 22, 2011
There should be white text next to the front panel connector on the motherboard labeling which connector goes where. this may also help:garthok.gif
E-Machines... | Answered on Apr 07, 2011
Hi, Thanks for using fixya.
Yes you may, I have 3 emachines with webcams attached.
Terry
E-Machines... | Answered on Feb 15, 2011
To reset the BIOS password read the information from this link.
E-Machines... | Answered on Jan 05, 2011
Some times the on switch goes faulty, dose the computer make any noise when
you turn it on, if not it could be the power supply...
E-Machines... | Answered on Nov 20, 2010
Here's a google page that has some links pertaining to the updating of your computer. Since I didn't have the make and model, I couldn't find any specific info for you, but I hope this helps:
http://www.google.com/#sclient=psy&hl=en&q=updating+a+emachine&aq=f&aqi=&aql=f&oq=&gs_rfai=&pbx=1&fp=b9249fd3d570d064
One person in a blog mentioned that they weren't getting good support from emachines, so you might try other blogs on the net that pertain to your motherboard/machine.
Good luck, and hope this helps.
E-Machines... | Answered on Nov 18, 2010
Look at the manual they tell you exactly which ones go where.
E-Machines... | Answered on Nov 02, 2010
Depends on what is wrong with the motherboard.
Capacitors? (Radial Aluminum Electrolytic Capacitor)
These are replaced by hand if you have good de-soldering, and soldering skills.
Visual signs of capacitor failure,
http://www.capacitorlab.com/visible-failures/
Identifying electrolytic capacitors used on motherboards,
http://www.hardwaresecrets.com/article/How-to-Identify-Japanese-Electrolytic-Capacitors/595
One place to buy them,
http://www.mouser.com/Passive-Components/Capacitors/Aluminum-Electrolytic-Capacitors/Aluminum-Electrolytic-Capacitors-Leaded/_/N-75hqw?Keyword=radial+aluminum+electrolytic+capacitor&FS=True
As for replacement of the motherboard chipset, (Northbridge and Southbridge), plus the GPU chipset, a Reflow Machine is used.
Example of a BGA Rework Station, (A type of Reflow machine)
http://www.bga-rework.us/
[GPU = Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU
When a GPU chipset is soldered directly to the motherboard, it is Integrated Graphics.
Another name for Integrated Graphics is OnBoard Graphics.
ON the motherBOARD.
A GPU chipset can also be soldered to a graphics adapter card.
Graphics Card, or Video Card.
The three major manufacturers of GPU's are Intel, AMD ATI, and Nvidia.
Motherboard diagram showing the Northbridge and Southbridge chipset's, in relation to the other components used on the motherboard,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The three major manufacturers of motherboard chipsets are Intel, AMD, and VIA.
{Chip and Chipset are slang terms for I.C.
Integrated Circuit }
If the above is not what you had in mind, please post in a Comment.
Regards,
joecoolvette
E-Machines... | Answered on Oct 26, 2010
Hi:
at the bare minimum, you can upgrade it with a PCI graphics card. That would plug into one of your spare white PCI slots, and they make those with atleast 256mb of memory ( When shopping for one, dont confuse a PCI video card with a PCI express card) I couldn't find enough info on what exact board you have, as they used several, but many had a brown AGP memory slot, which is a better option for you. Keep in mind, also, that if you upgrade the video card and memory , you might need to upgrade your power supply too, due to the higher current requirements of the new card and memory.
If all else fails, bring your tower to a computer shop, and they will usually tell you what you need for free, with hopes to sell a upgrade!
E-Machines... | Answered on Oct 16, 2010
That is going to depend on what it was set to. There is no factory password for the Bios on these computers. If you have forgotten the password you will need to reset the Bios using the jumper on the mother board. If you don't have your book on the motherboard you will need to go to the eMachine website and look up the down load of the book for your specific model.
E-Machines... | Answered on Oct 12, 2010
You can boot in safe mode to download the driver and install it. To boot in safe mode, press F8 while booting up and choose Safe Mode from the options. The driver of that machine can be downloaded on the following page.
http://www.emachines.com/support/drivers.html
Select Desktop, then D series and then D2266 and make sure the right version of Windows is selected.
The user manual can be downloaded on the following page.
http://downloads.emachines.com/userguides/Desktop_UG_Nexgen2_3_en.pdf
E-Machines... | Answered on Sep 10, 2010
the power supply you installed does not have enough power to run your video card
E-Machines... | Answered on Sep 06, 2010
try a new vidoe card.
E-Machines... | Answered on Sep 01, 2010
E-Machines (308714) Motherboard Logo
97 questions posted
Top E-Machines Computers & Internet Experts
Thomas F. Schneider
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • E-Machines Computers & Internet
Most Popular Question
need diagram d33007 motherboard
  • Computers & Internet
