20 Most Recent E-Machines eMachines T3830 PC Desktop Questions & Answers
ok what you want to do is restart the PC and keep tapping F8 when it asks you to start windows in safe mode or with networking hit enter on windows safe mode ... not with networking any ways... it will then ask you to log in Type in user name Administrator and then hit Enter .. go to control panel change your password jobs a gooden :D Good Luck
E-Machines... | Answered on Jul 21, 2019
Since Vista is a very old operating system you’re going to have quite a challenge finding tools that will solve your problem
- In this particular case you may want to go to a local PC repair shop that would have the old operating system discs you’ll need to restore
- From your description it is tough to figure out whether this is a software problem or if there is something physically beginning to fail on your machine but I can tell you from experience that with the machine of that era you have a hard drives that are at least 10 years old
E-Machines... | Answered on Jan 06, 2018
It is unlikely that this program deleted your Facebook account but it may be interfering with your ability to access it. Start by removing the program. Remove PC HealthBoost Virus Removal Guide
E-Machines... | Answered on Jun 11, 2017
I had something similar happen to ma about a year ago, I moved my tower a couple inches to reach for something that fell and then my screen was "colorful". Turned out that I just knocked my monitors cable out just enough that it was not working properly. I would first check to see if either end of the monitor cable has come loose from the computer tower or the monitor itself.
I have also had the colors go wild when I had a faulty video graphics card, but I would start with the cable first to make sure it is secure.
E-Machines... | Answered on Aug 12, 2015
give me your email. I will send a picture of Front panel connections. BTW are you a tech or feel comfortable to T/S further?
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
E-Machines... | Answered on Mar 19, 2015
look up some password utilities, sometimes you can download something to reset the password on the local machine and be good to go.
E-Machines... | Answered on Jan 29, 2015
open case locate the hard drive unplug cabled unscrew it side it out and reverse to install
E-Machines... | Answered on Nov 19, 2014
Found this answer given by max carson as an answer to a similar question so I'll give the credit to him
In Safe Mode, run MSCONFIG, you didn't specify the OS, for Win 7 use this
:http://www.netsquirrel.com/msconfig/msconfig_win7.html
In the GENERAL tab select Normal Startup, click on APPLY, OK, RESTART.
Hope this helps
E-Machines... | Answered on Jul 18, 2014
What account?
There is little point in posting a question with no real information.
Saying something is "broke", "doesn't work", "can't connect" or that you "need" or "want something" is pointless without ALL the information.
What actual products are you using? Makes, models, connections...everything about your problem is necessary. We are not there with you. We cannot see what is obvious to you. Most problems occur when you try to get something to work with something else. We need to know all the things you are using and doing that ends with your issue.
The issue is the last thing we need not the only thing.
If you did something stupid, then tell us. We aren't going to laugh at you, we want to help you. In all likelihood we did something similar and so we know if it can be fixed.
If you hope that by lying about the situation we will be able to fix your issue, you are WRONG.
If you are trying to do something illegal we know about that too.
We want to help you. We do not get paid for our work. We do it because we want to share our knowledge and help you.
If you do not post complete information, most likely your question will go unanswered, so you wasted your time and our time reading your post.
E-Machines... | Answered on Apr 02, 2014
Use password remover tools on Hirens
E-Machines... | Answered on Dec 09, 2013
If you deactivate your account from the "Deactivate Account" section on the Account page, your profile and all information associated with it are immediately made inaccessible to other Facebook users. What this means is that you effectively disappear from the Facebook service. However, if you want to reactivate at some point, we do save your profile information (friends, photos, interests, etc.), and your account will look just the way it did when you deactivated if you decide to reactivate it. Many users deactivate their accounts for temporary reasons and expect their information to be there when they return to the service.
If you do not think you will use Facebook again and would like your account deleted, please keep in mind that you will not be able to reactivate your account or retrieve any of the content or information you have added. If you would like your account permanently deleted with no option for recovery, log in to your account and then submit your request by clicking here.
If you are currently unable to access your account, you will need to reset your password in order to log in. In order to do so, click the "Forgot your password?" link that appears above the field where you would normally enter your password. Once you’ve followed the instructions to reset your password and can log in, you can deactivate or delete your account using the steps outlined above.
E-Machines... | Answered on Sep 21, 2013
Click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in facebook.com) or your preferred browser Internet search facebook login Once logged in in the right hand corner on the facebook homepage you will see ACCOUNT from the drop down list will be Edit friends Account settings Privacy settings Help center and Log out you could use the help center type in you problem you might have to wait a for 2/3 days for a reply due to overloading on this site also http://www.filebuzz.com/fileinfo/87599/Facebook_Login.html Facebook Login software is freeware specially designed for Facebook browsing. This simple application has many features for you. Application is more speeder and secures Facebook browsing than your normal... If your Facebook profile is still unavailable after many days, then send an email to
info@facebook.com, appeals@facebook.com or disabled@facebook.com and explain them the issue. http://www.facebook.com/help/?page=121467344601554 Once you send them an email, your account will be available again soon.
E-Machines... | Answered on Apr 08, 2013
just go to facebook.com to resign up
E-Machines... | Answered on Feb 01, 2013
Hi and welcome to fixya
firstly check your power cable of the CPU and then if this isn't works then put the RAM from the CPU and then reinsert it if still isnt work then there should b a hardware problem
E-Machines... | Answered on Dec 08, 2012
If you go to the eMachines website you can download an owners manual off of the site for your system. Hope that this helps..
E-Machines... | Answered on Dec 01, 2012
If you using windows, Login to administrator account with current password, than open command prompt by click in Start Menu -> Run, and type CMD (pres enter)
While a black window of command prompt appear, type this command
net user administrator your_new_password (hit enter button)
E-Machines... | Answered on Nov 15, 2012
E-Machines eMachines T3830 PC Desktop Logo
189 questions posted
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
T E-Machines
  • T E-Machines
Most Popular Question
lost emachines t3642 owners manual
  • Computers & Internet
