20 Most Recent E-Machines W1800 PC Desktop Questions & Answers
5answers
Motorola W180 Driver
Here is USB Drivers installation procedure for Locosto USB based models :
  • Run "Motorola Driver Installer.exe" from "C:\Program Files\Common Files\Motorola Shared\MotPCSDrivers\" dir
  • Select "Clean only" and press start, wait untill its finished then close the software,
  • Open Control Panel, Add/Remove Programs and uninstall Motorola Drivers
  • Open Rocker Dongle Support, and navigate to ".. / .. / RockerDongle / Drivers / W156i_W160_W175_W180_USB_Drivers / dir.
  • Download and install "Motorola.9.0.msi"
  • Restart PC
  • Connect above mentioned Motorola model with mini USB cable to pc, with battery removed
  • Insert battery, windows will detect "LOCOSTO" device and install drivers
  • Remove and insert battery again, and check in device manager for "Motorola Flash" device.
If You have done everything as described, You will have installed drivers correctly. Take note, these models will remain in flash mode for only 5 seconds, if no comunication started, phone will go to charging mode.
11/18/2014 4:44:48 PM • E-Machines W1800... • Answered on Nov 18, 2014
4answers
W180 Driver
9/5/2010 8:04:32 PM • E-Machines W1800... • Answered on Sep 05, 2010
When I plug into usb it doesnt recognize it
while your phone is plugged in go to start, control panel, add new hardware and go through the setup wizard.
3/5/2010 3:45:52 PM • E-Machines W1800... • Answered on Mar 05, 2010
I HAVE A W 180 MOTOROLA TRACFONE AND I TRY TO
You need to find and install Motorola phone tools. It works with your Motorla phone to put pics on and make your own ringtones if your phone supports polyphonic ringtones and pictures.
12/1/2009 3:36:38 PM • E-Machines W1800... • Answered on Dec 01, 2009
What do i need to download ringtones to my W180
you can download the ringtones at www.zedge.net/ringtones/1777/motorola-w180-ringtones/
11/3/2009 11:02:16 AM • E-Machines W1800... • Answered on Nov 03, 2009
Need cd for charging w180 phone via usb
Hi:
There is no CD To charge your phone via a usb port, you just need the appropriate cable , and it is just plug and play!
10/24/2009 12:58:06 PM • E-Machines W1800... • Answered on Oct 24, 2009
Need cd for charging motorola w180 phone via usb
This is all you need...download this
http://www.freedownloadscenter.com/Business/Misc__Phone_Tools/Motorola_Phone_Tools.html
10/23/2009 12:03:50 PM • E-Machines W1800... • Answered on Oct 23, 2009
I dont have the disk
what are u talking about? Just download the songs and sync them to phone using windows media plyr
9/29/2009 2:14:52 AM • E-Machines W1800... • Answered on Sep 29, 2009
Where can i find a free copy of adobe illustrator
shh someone said the piratebay bittorrent.....
6/21/2009 11:55:47 AM • E-Machines W1800... • Answered on Jun 21, 2009
Instalar programa W180 via USB
http://www.4shared.com/file/54810194/eb0b16b8/Motorola.html
Faça o download e instalar.
6/17/2009 3:42:12 AM • E-Machines W1800... • Answered on Jun 17, 2009
Instalar programa W180 via USB free download
i can solve this problem.But i want details
6/16/2009 3:37:00 PM • E-Machines W1800... • Answered on Jun 16, 2009
2answers
Moto w180
plz visit the motorola website and download the drivers
4/26/2009 12:12:42 PM • E-Machines W1800... • Answered on Apr 26, 2009
mi computadora no reconoce mi telefono mobil ala hora de querer descargar tonos
3/15/2009 12:20:25 AM • E-Machines W1800... • Answered on Mar 15, 2009
I tryed to restore my emachine w1800 with my
could be a couple of things, usually when you get the BSOD (blue screen of death) there is usually a ram problem, have you noticed your pc getting slow, sometimes the ram sticks break down over a period, try getting hold of a memory tester software and checking the PC, this is usually done through the inital start up before windows is loaded, please ensure though that if you need to get more ram that you use the correct one for your motherboard, buying incorrect ram can cause more problems and is a waste of money, www.crucial.com is good for checking ram in pcs, also you need to make sure that if it says low density you use low density ram, or high density for high density. also make sure that you buy the one with the correct amount of pins.
hope that this helps
3/1/2009 2:09:56 AM • E-Machines W1800... • Answered on Mar 01, 2009
Same here!! W180 drivers for EMachines PC...Anyone
follow the link below for the drivers.
Let me know if it helps,
Thanks,
Mark
2/27/2009 3:25:16 PM • E-Machines W1800... • Answered on Feb 27, 2009
I can't find motorola w180 driver. who can help me
here is driver link for your phone
click on it & download
http://direct.motorola.com/hellomoto/in/support/driversNplugins.asp?country=aus&language=ena#
Good Luck!
neo
2/27/2009 8:22:19 AM • E-Machines W1800... • Answered on Feb 27, 2009
Motorola w180 driver
12/9/2008 7:14:09 PM • E-Machines W1800... • Answered on Dec 09, 2008
Emachies w3609 3 beep codes
Verify that the keyboard is connected properly to the computer by turning off your computer and then disconnecting and reconnecting the keyboard to the computer. Stuck key Ensure that there are no stuck keys on the keyboard. If all keys appear to be ok and you have a standard desktop computer with keyboard, turn the keyboard over and gently hit the back of the keyboard to loosen any dirt or hair that may be stuck in the keyboard. Bad keyboard Try another keyboard on the computer to verify that the keyboard has not gone bad. Bad PS/2 or AT port If all of the above solutions are not able to resolve your issue it is likely that the port on the back of the computer may be bad and the motherboard or I/O board may need to be replaced. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in Test all power and data leads that attach from motherboard to your hard drive IDE SATA make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40 pin ide it will be the first to fail check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it restart your computer the found new hardware wizard should activate a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function. Hope this helps.
1/4/2013 4:27:14 AM • E-Machines W... • Answered on Jan 04, 2013
E-Machines W1800 PC Desktop Logo
Popular Tags
20 questions posted
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
W E-Machines
  • W E-Machines
Most Popular Question
when plug into usb doesnt recognize
  • Computers & Internet
