Want to connect two korg d3200's to use as one recorder
I will assume you want to sync the two as one. I have one of these sitting in a closet. The 3200 will record 12 tracks at a time if I remember correctly. I believe the Korg will sync to Midi Time code. I just wonder if the midi implementation allows for start and stop code. Anyway, I found this information:
x2. MIDI messages used by the D3200
Note On (Note, velocity), aftertouch, pitch-bend:
The D3200 uses these messages to control effects.
Program change:
The D3200 uses these messages to switch scenes.
Control change:
The D3200 uses these messages to control mixer and
effect parameters.
MMC (MIDI Machine Control):
MMC messages can be transmitted from the D3200 to control an external MMC-compatible sequencer or recorder. MMC messages received from an external sequencer or recorder can be used to control the D3200.
MTC (MIDI Time Code):
The D3200 can transmit or receive MTC messages to
synchronize with an external sequencer or recorder.
MIDI Clock:
The D3200 can transmit MIDI Clock. It can also receive MIDI Clock if you have selected MIDI Clock for the tempo track and are recording the tempo track.
SOURCE: can't connect the h4 handy recorder to a mac
If you are using a Mac running Leopard (Sys 10.5), you need to upgrade the H4 firmware from Zoom website
http://www.zoom.co.jp/english/download/software/h4.php
You will need an external SD card reader.
Good Luck
SOURCE: I need help with my Boss Micro BR. I want to
Go to bossbr.net - Plenty of answers there! And yes, you have to master or export the tracks to .mp3 or .wav. These files will be located in the mp3 folder. Boss also makes a free .wav converter located on their website.
SOURCE: Boss 900 digital recorder
from reading instructions when you record channel 1 and 2 you are recordind channel 1 in stereo so you only recorded channel 1 try rcording on chanel 3 for vocal hope this helps
SOURCE: how do i connect active speakers to a BOSS br 1600
I would come out of the line out jacks on the studio into the line in jacks on the speakers. Make sure both ends of the cables have the correct plugs on them. I'll include a link in case you don't have the correct manual:http://www.alesis.com/content1023
SOURCE: how can I save my
Recording a new tune automatically deletes the previous one.
Solution transfer the recorded song to your computer via USB cable.
It is also possible to store up to 5 additional tunes in the song bank
See page E50 and appendix 9 of the user manual available here. http://support.casio.com/pdf/008/ctk_810_01_e.pdf
