20 Most Recent Korg D3200 Studio Package Questions & Answers
2answers
As usual with the korg d3200 the locate buttons
If the buttons are just sticking at their sides in the panel, lube with a tiny bit of CRC 226 on a Q tip. Get the CRC226 at Home Depot in the electrical dept. If the button mechanisms have failed or plastic hinges have broken then replacement is only option. Losing 4 of these to same problem is RIDICULOUS... time to change brands.
8/25/2021 2:55:31 AM • Korg D3200... • Answered on Aug 25, 2021
IMPORTING FILES INTO THE KORG D3200
The import needs to happen from a computer (or a CD-RW) >D3200, not from a flash drive or backup drive.
4/29/2016 2:23:58 PM • Korg D3200... • Answered on Apr 29, 2016
I have a Korg D3200. I want to make a rhythm loop
do you have the owner's manual if not download it-there are /were you tube videos for what your trying to do- they helped me alot - when you plug your guitar into the guitar jack on channel 1 you can't use the xlr input 1at the same time in addition be careful not to blow the audio system there are no replacement parts for this system
4/8/2014 4:10:53 PM • Korg D3200... • Answered on Apr 08, 2014
Speakers for D3200
yes- check out the m-auduo studiophile speakers & there are other brands that are better depending on your wallet.
4/8/2014 3:31:35 PM • Korg D3200... • Answered on Apr 08, 2014
0answers
2answers
I managed to erase al
You need an application to recover your deleted files.
Some of these data recovery applications are free and does not cost you a dime.
Others you will have to purchase.
Here is a YouTube video that show you how to recover your deleted files.
http://www.youtube.com/watch?v=ndLXZbqQRAY
Good luck
9/3/2013 1:32:16 AM • Korg D3200... • Answered on Sep 03, 2013
All led's are lit up clipping upon powering on,
That sounds like an excessive repair bill. It sounds like it was a failure in the power supply. Read the repair order and add that info here.
8/20/2013 8:01:43 PM • Korg D3200... • Answered on Aug 20, 2013
2answers
Hello my peak lights wont
Please try to power reset the unit. Pull out all power cables and wait about 20min.
Best of Luck
7/20/2013 5:28:02 PM • Korg D3200... • Answered on Jul 20, 2013
2answers
Have korg d3200. gray
Korg is a great company and when you contact them they will help you. They can tell you how to get the CD and/or how to download and burn it to your own CD. then you can boot up the device
2/27/2012 4:19:08 PM • Korg D3200... • Answered on Feb 27, 2012
2answers
Hi, I send you a message about deleted files from
Hello
Can you explain how did you adjust the space on your computer?
9/8/2011 6:44:21 PM • Korg D3200... • Answered on Sep 08, 2011
We laid down 5 tracks
Somehow proper save and shutdown was not done. You said the magic word PANIC... That is a deadly word in this situation. So first thing like for lost files on a PC is to look around... carefully. LIKELY the files are still there, just under a different folder or imbeded in another project. These systems do a pretty good job of not letting one clobber their files without confirming AS LONG AS proper shutdown procedure is used or power doesn't fail. The five tracks you might have forgotten to save...but the other should be there.
5/20/2011 2:07:45 PM • Korg D3200... • Answered on May 20, 2011
Hi,, the stop button and channel one on my korg
Unless you are electronically adept and have certain tools I would NOT attempt this yourself. You could damage the circuit board causing great repair expense.
2/24/2011 6:08:14 AM • Korg D3200... • Answered on Feb 24, 2011
0answers
Where online is the manual pls for the korg 3200
Here is a link to the manual:http://img3.musiciansfriend.com/dbase/pdf/man/m_242061.pdf Just remember the mentioned site has lots of support for other brands too.
10/22/2010 2:51:47 PM • Korg D3200... • Answered on Oct 22, 2010
Korg3200 no input no outpu
Go through the manual
http://media.zzounds.com/media/D3200_E1-0b1b188ba8292cca3f022268d3632c1f.pdf
6/9/2010 12:11:18 PM • Korg D3200... • Answered on Jun 09, 2010
All inputs lights red (clip)
hi
you will find your solution from folowing site
http://www.zzounds.com/item--KORD3200
6/9/2010 11:12:09 AM • Korg D3200... • Answered on Jun 09, 2010
I need a fuse for a Korg N364 keyboard.
No one knows the fuse type, but the details should be on the fuse itself. Then you can't get them from an electronics store or Amazon. The Service Manual is in the link. https://www.google.com/search?q=Korg+n364+keyboard+replacement+fuse ..
4/12/2024 4:58:31 AM • Korg Music • Answered on Apr 12, 2024
Korg D3200 Studio Package Logo
Popular Tags
21 questions posted
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
View Most Popular
Korg Music
  • Korg Music
Most Popular Question
as usual korg d3200 locate buttons
  • Music
