20 Most Recent Korg M50 61-Key Music Workstation Keyboard - M5061 Questions & Answers
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop. If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
7/22/2020 10:14:02 AM • Korg M50 61-Key... • Answered on Jul 22, 2020
Mainboard error
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything someone on fixya recommended it to me and I thank him even today
2/1/2019 10:20:12 AM • Korg M50 61-Key... • Answered on Feb 01, 2019
Korg m50 freezes, read in other forums that the problem may be to replace 2 capacitors, do anybody knows wich ones? or have a solution?
My opinion is that the capacitors are in the power supply. If they get old, they leak (electronically) and pull down the power output of the supply. They will be larger than any of the other capacitors in the circuitry.
11/30/2018 7:36:43 AM • Korg M50 61-Key... • Answered on Nov 30, 2018
2answers
Korg M50 keeps freezing up how to fix took it to repair and it still does it
Well looks like you have a capacitors problem. I had this problem too and a friend soldered two new capacitors in place. You can find information on the korg forum but most important is to know where the capacitors are located http://www.korgforums.com/forum/phpBB2/viewtopic.php?t=92395
5/5/2018 9:07:16 PM • Korg M50 61-Key... • Answered on May 05, 2018
Does this keyboard have a button battery inside?
Yes, just the same cmos battery the desktop computer use. easy to replace, located on the main control board.
9/9/2016 6:28:07 AM • Korg M50 61-Key... • Answered on Sep 09, 2016
I want to record from my Korg M50 to Cubase LE4 on my laptop.
Hello, To record into a lap top you will need a USB mixer, your audio output from the SYNTH will go into the mixer, you use the midi USB cable from the mixer to the lap top. this will help pre amplify your synth to normal audio levels. hope this helps.
1/19/2016 5:17:08 AM • Korg M50 61-Key... • Answered on Jan 19, 2016
Korg m50 freezes after 10minutes
Hello I have this M50 61 key korg model, I had the same issue the fix is simple remove the back cover on the unit, carefully push in all the small cables reattach them well do it to all the small connectors these cables get lose and cause this issue, good luck let me know if that helped I fixed mines that way its been working excellent since. good luck..
1/19/2016 4:55:51 AM • Korg M50 61-Key... • Answered on Jan 19, 2016
2answers
Why is gm voice not playing?
Hello, You may want to reset your machine, all data and pre loaded programs, for this you must turn on your M50 press the global mode button, click on the top arrow next to (basic) select option 2, load pre-preloaded demo data, you then choose all (PCG and demo songs). press OK. Your Korg will re install all factory samples, data and settings. Once completed It will then instruct you to turn off your machine. give it a minute or so to self upgrade before turning it back on, once you turn it back on you should see updating panel notifications right and left, you should be able to use all of the sounds and combi's available for M50. that's a factory reset. I hope this helps, Have a great day.
1/19/2016 4:52:01 AM • Korg M50 61-Key... • Answered on Jan 19, 2016
2answers
When power on then display show internal memory formatting failed
For the best answer contact Korg customer service. Here's the link- http://www.korg.com/us/support/contact
11/9/2015 10:48:06 AM • Korg M50 61-Key... • Answered on Nov 09, 2015
2answers
Update right and left pannel please turn off what problem
Up date right and left and then turn the power off. What wrong or who to operate of korg m50-61
5/1/2015 1:40:43 PM • Korg M50 61-Key... • Answered on May 01, 2015
Hello, I own a Korg M50 myself and I had the same issue, its a quality control issue at their factory but, I may have a solution for you I found at a Korg forum. the issue is with these teeny cables inside the synth. you open the rear panel and firmly press each teeny cable into the terminals again and re attach and secure them firmly just finger push them all into their teeny sockets. this should stop the freezing I tried it the synth played all night with out freezing . I hope this helps other wise the solution with the capacitors is simple you order a new mainboard but they run about 400 plus. but try my solution it may work for yours this answer comes from a korg tech, he stated 90% of this freezing issue he has encountered has been these loose teeny cabling adapters, hope this helps, Have a great day..
4/2/2015 7:32:04 PM • Korg M50 61-Key... • Answered on Apr 02, 2015
My corg m50 board not orking gm not ork
Your best bet would be to contact Korg directly. Here is the link to their USA support page Contact KORG
2/12/2015 6:34:05 AM • Korg M50 61-Key... • Answered on Feb 12, 2015
Moving to Canada Korg M50 - 220V to110V ?
110 will not damage it, just will not work, if built in power supply should say on the rating plate next to power input the voltage it is able to take, a lot of units are rated 110-240v some will have a small switch to change over from 110 to 240. Other than that, you will need to get a step up unit to supply 240 from 110 just a small transformer unit.
3/6/2013 10:47:59 AM • Korg M50 61-Key... • Answered on Mar 06, 2013
0answers
0answers
Korg M 50
Korg Support advises that they can either provide you end cap or direct you to a retailer. CLICK HERE
5/23/2012 4:24:45 PM • Korg M50 61-Key... • Answered on May 23, 2012
2answers
Where can I get the Korg m50 service manual or
http://www.korg.com/SupportResults.aspx?productid=413 just click here :)
9/22/2011 6:02:19 PM • Korg M50 61-Key... • Answered on Sep 22, 2011
Korg M50 61-Key Music Workstation Keyboard - M5061 Logo
Popular Tags
30 questions posted
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
View Most Popular
Korg Music
  • Korg Music
Most Popular Question
when power display show internal memory
  • Music
