20 Most Recent Korg X5d Questions & Answers
KOrg X5D is out of tune
Did you try to get to Global mode, and then check if the tune is 440 hz? Check the Global Settings. The tuning might either be altered or the key transposed..
12/10/2021 12:36:45 PM • Korg X5d • Answered on Dec 10, 2021
My korg x5d doensn't show bank A anymore. Instead of A01 - pipedreams lcd screen shows blinking A01 and InitProg01???
You can try this.STEP 1:Set Program protect and Combi Protect to OFF.- GLOBAL- Using PAGE+ or PAGE-, find untill the display show "3A-MEMORY PROTECT". Set the parameter to OFF by using YES or NO button.STEP 2:Data Load.- GLOBAL.- Using PAGE+ or PAGE-, find untill the display show "05A-PRESET DATA". Change ALL to PRG (your case). Use Left/Right Arrow button to moving cursor. Choose "PRE-a" (your case). Move cursor to "OK?". Press YES when "OK" blinking for confirm. Exit (Go to PROG button).
12/19/2017 8:05:57 AM • Korg X5d • Answered on Dec 19, 2017
0answers
My korg x5d combination sound gone
4/29/2016 2:08:53 PM • Korg X5d • Answered on Apr 29, 2016
3answers
My korg x5 keyboard only turns on but nothing
Download the owners manual from here and try doing a reset to factory settings
http://www.korguksupport.co.uk/page.cfm?pageid=391#Owners Manuals
3/13/2016 3:57:48 PM • Korg X5d • Answered on Mar 13, 2016
My X5d displayed "05 31 1995" then stopped functioning..what shall i do?
That sounds like a manufacture date being flashed. Have you checked the battery? If you can't backup first, all your changes (custom sounds) will be lost, but that might be what you are looking at. Replace the battery, or have a service center do so. You'll want to reset after. Try ROM check first. Initialization: Hold Page + and Page - while turning it on. Preload: Global Screen 5A, then select "OK". ROM Check: Hold Edit and Global/Multi while turning it on. Guide: How to Initialize reset and preload on the Korg X5 X5D DR SweetCare
12/19/2014 4:29:26 PM • Korg X5d • Answered on Dec 19, 2014
How to reset korge x5d to factory setting?
Hold PROG and +10 while turning it on. That should initialize the unit to factory fresh.
10/16/2014 12:16:01 AM • Korg X5d • Answered on Oct 16, 2014
0answers
How to save x5d sounds in laptop
Hi, if you do not already use a midi sequencing software try "Bome's SendFX". After installing, go to X5D menu 04A MIDI DUMP, choose data you want do dump (e.g. "all"). Make sure, that no SYSEX FIlter is active while working with a sequencing software. After transmission, you can save the "yoursounds.mid" file and send it back to the X5D later. Good luck!
4/20/2014 12:15:55 PM • Korg X5d • Answered on Apr 20, 2014
0answers
Low battery korg x5
Be the first to answer 3/24/2014 9:23:40 PM • Korg X5d • Posted on Mar 24, 2014Be the first to answer
0answers
Pitch Wheel
Be the first to answer 3/23/2014 12:55:46 AM • Korg X5d • Posted on Mar 23, 2014Be the first to answer
0answers
0answers
0answers
Korg x5d no sound
Be the first to answer 11/27/2013 3:00:48 AM • Korg X5d • Posted on Nov 27, 2013Be the first to answer
0answers
Korg X5d Logo
50 questions posted
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
View Most Popular
Korg Music
  • Korg Music
Most Popular Question
  • Music
