20 Most Recent
Korg D3200 Digital Studio Questions & Answers
Start up screen stuck
Did you try boot from the CD with the OS? is it the Same? Did you replace the hard dirive with another?
Is the HDD/CD disk light flashing or illuminate during power up? It should!
How to recover deleted data
you can obtain undelet software to do this but do not use the machine too much before attempting the procedure, too much use might lead to the areas where data was stored becoming written over. If the data was very important I would contact a data recovery specialist, one with a proven track record.
Good Luck
I have to push many
Probably the button mechnisms are worn. The heavily used buttons often have the plating worn off and become intermitent. Have the button mechanisms replaced. Make sure to use the long life version of the buttons.
When I connect the Mackie 1642-vlz3 from the
Make sure ALL of the interconnected equipment is powered from the SAME receptacle to avoid ground loops due to the safety ground. DO NOT Use two wire power or use ground lifting plug adapters. Make sure you use balanced lines, either XLR or TRS cables. Do NOT use TS cables.
