20 Most Recent Korg miniKP mini KP KAOSS PAD Effect Processer Sampling Questions & Answers
I need a fuse for a Korg N364 keyboard.
No one knows the fuse type, but the details should be on the fuse itself. Then you can't get them from an electronics store or Amazon. The Service Manual is in the link. https://www.google.com/search?q=Korg+n364+keyboard+replacement+fuse ..
4/12/2024 4:58:31 AM • Korg Music • Answered on Apr 12, 2024
Korg D3200 asks for start up disc. Will not boot.
If you contact Korg, they can send you a dowloadable link to burn the software to a disc.
11/21/2023 9:36:55 PM • Korg Music • Answered on Nov 21, 2023
Hello. I am in possession of Ix300 Korg music workstation that is not able to boot up properly. Any chance of repairing?
up to you if you ant to spend the money to have it diagnosed and repaired
11/3/2023 2:31:49 AM • Korg Music • Answered on Nov 03, 2023
Loading system failed Korg m50
9/6/2023 8:00:59 AM • Korg Music • Answered on Sep 06, 2023
2answers
Korg X50. When switched on, why does it indicate: 'Waiting for the data from USB'?
Sounds like loss of memory\programming.Go to Korg website for download.
12/30/2022 3:04:37 AM • Korg Music • Answered on Dec 30, 2022
How to reset the korg radias to factory settings
7/23/2022 8:23:24 AM • Korg Music • Answered on Jul 23, 2022
I have a korg n1 and when I turn it on the display screen comes on but no words show up on it I was wondering how to fix it
It sounds like your ROM battery, which the ROM contains and stores the patches for the keyboard, has gone completely dead and your keyboard is dead in the water. However, if you can get a MIDI to USB converter and get the battery changed, then you can reload the patches back onto the keyboard. I have worked on a Korg M1 Workstation and have had to replace the battery(CR2032) and then had to run a program called "MIDI-OX" which also gave me access to the patches needed in order to restore the keyboard to factory patch settings. http://www.midiox.com/ Take a look at this AFTER you have gotten the battery replaced. I will tell you that replacing most batteries is a very intricate job as, the bottom of the keyboard has to be removed, as well as a lot of the internal boards. I had to draw a diagram and mark certain pieces so I would know where they went and in what order they have to be re-attached. My advice is take it to someone who works on electronics unless you want to DIY (not recommended) to get the battery replaced. Hope this helps.
3/8/2022 8:37:05 PM • Korg Music • Answered on Mar 08, 2022
On my Korg X2 workstation, the LCD screen displays INIT I the combination A & B banks, and the program A & B banks. The same sounds is in all of these settings and I can't change it. How do I fix it?
How to Initialize (reset), and preload on the Korg X2/X3/X3R Initialization: Hold Page Down and 0 while turning it on Preload: Disk Load (XSD00P) ROM Check: Hold Enter and 7 while turning it on. If banks names are lost, you need to replace the little round coin-pill from inside, which memorize settings while the instrument is off and disconnected from the power.
3/8/2022 8:32:36 PM • Korg Music • Answered on Mar 08, 2022
3answers
I am looking for a Korg i4s service manual?
Give your email, I'll send for free.
3/1/2022 7:38:09 AM • Korg Music • Answered on Mar 01, 2022
Korg d3200 has buttons that dont always work, sometimes i have to push them several times.
The buttons are damaged or defective. Replacement may be the only answer.
8/5/2021 3:01:35 AM • Korg Music • Answered on Aug 05, 2021
My korg m50 audio output R-L MONO VOLUME OUT IS TOO LOW
Might be a case of opening up the M50 as the previous poster did and wiggle connectors and components until the sound is affected. If you have some electronics experience, it should be fairly easy to figure out which board to investigate.
7/15/2021 7:01:15 AM • Korg Music • Answered on Jul 15, 2021
Korg miniKP mini KP KAOSS PAD Effect Processer Sampling Logo
Popular Tags
0 questions posted
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
View Most Popular
Korg Music
  • Korg Music
Most Popular Question
touch panel problem in korg m50 found
  • Music
