20 Most Recent Korg D888 8 Track Recorder Questions & Answers
My experience with these is fairly limited. I find they have to be happy in all respects before they will work at all. When we had our digital switchover the signal strength quadrupled and many top boxes just stopped working while others kept freezing or pixelating. It wasn't until suitable attenuators had been fitted they settled down and began to work.
Lots of people who bought hdd recorders found them unsatisfactory and I know one guy who tried four before he found one that worked for him.
My first hdd recorder had a very short life so I upgraded and got an even worse one so I complained to the manufacturer. After several emails it seemed my new purchase had the oldest software version available. Since the software has been updated it has been quite acceptable.
You didn't say whether the trouble was with playback or tv viewing but I speculate there isn't much wrong if the device boots ok. The software will be stored behind a partition on the hdd. I suggest you check your signal strength and then try updating the software before resorting to sending the unit back for service.
Korg D888 8... | Answered on Jun 16, 2016
If you have updated your computer OS it may no longer be compatable. Other than that do a herd reset on the Korg and see if that helps.
Korg D888 8... | Answered on Sep 23, 2015
Not a solution but a question that might get you closer to resolving this. Have you attempted to connect to any other computer with your D-888. Did this work?
Korg D888 8... | Answered on May 01, 2013
It is asking for confirmation that you want to initialize the unit. The manual doesn't say anything about this... but you should try pressing the "Yes" button to confirm you want to initiallize the unit or press no if you want to staart without initializing.
Korg D888 8... | Answered on Aug 16, 2011
Most common cause are failed connectors. Power inout jack failures are common. Beyond that, tracing out the power input for a failure would be in order.
Korg D888 8... | Answered on Aug 15, 2011
The hard drive has probably failed. In spite of it rotating, the head servo and electronics has to work. I would recommend testing the drive in a computer to see if it works. You will likely have to reformat it after if it does work. FIRST look for obvious things in the D888 like cable that is partially off or loose.
Korg D888 8... | Answered on Aug 06, 2011
First thing would be to check the power supply voltages. It may be the disk drive is failing. Drives are inexpensive, might be worth a try with a new drive. Also check that cables to the drive have not been loosend by handling.
Korg D888 8... | Answered on Jun 18, 2011
check to see if your in monitor mode, seems like yout not
Korg D888 8... | Answered on May 31, 2011
http://www.korgforums.com/forum/phpBB2/viewtopic.php?t=70279&sid=0a3c1fcbb6e1dac75c1a6975f3a1292f I've found this in my files:
01/W Series Initialization: Hold Reset and Compare while turning it on. Preload: Global screen 7 Press G then E it will if OP turns off write protect in the global menu. None of the resets or reboots will do anything until the synth is allowed to use them. If write protect is ON all changes will be rejected.
Korg Music | Answered on Apr 12, 2019
Email Korg customer service in your country for advice, or search the manual if you have it.
Korg Music | Answered on Apr 03, 2019
Korg D888 8 Track Recorder Logo
24 questions posted
Top Korg Music Experts
Michial Gueffroy
Experi
Level 1 Expert
David Gust
Are you a Korg Music Expert? Answer questions, earn points and help others
View Most Popular
Korg Music
  • Korg Music
Most Popular Question
plug usb from d888 laptop toshiba
  • Music
