Refrigerators Logo
Robin Kay Tabor Posted on Jun 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My frigidaire ffhs2311pfba freezer is leaking water to the bottom of the freezer. Once frozen it will start to leak outside the freezer. I cleaned off the ice maker but not the post behind it as it is frosted over. Could this be the problem? Or the fan in the back of the freezer?
David Del Polito
Level 2:
Habit-Forming:
New Friend:
  • Expert 44 Answers
  • Posted on Jun 20, 2019
David Del Polito
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
44
Questions
0
Helped
19718
Points
108
Sounds like the defrost drain at the bottom of the freezer section is frozen over and clogged.
shut the refrigerator off, remove the food in the freezer
remove the shelves
remove the lower panel on the rear wall
at the bottom is the drain pan with a hole
my guess that it is full of ice?
use hot sink water and remove the ice
then use a turkey baster to clear the hole and the hose.
If the water still won't drain your going to have to manually clean the hose.
5 Related Answers
Anonymous
  • 1073 Answers
  • Posted on Apr 12, 2008
SOURCE: Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
Anonymous
  • 725 Answers
  • Posted on Sep 07, 2008
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Anonymous
  • 1543 Answers
  • Posted on May 12, 2009
SOURCE: Water leaking from freezer
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
This will prevent water from comming out the freezer door and leaking onto your floor and running down your copper pipe to the basement.
Anonymous
  • 72 Answers
  • Posted on Jun 17, 2009
SOURCE: Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Anonymous
  • Posted on Jul 03, 2009
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Ice maker working, but water leaking from inside at the bottom of freezer.
You have a frozen drain. Remove back panel in the freezer, remove ice build up and flush hot water through drain until clean.
Ice is forming in the bottom of my side by side fridgedaire freezer and once its 1/4 inch thick starts to melt and leak from the freezer onto the floor. I then take out the ice built up and the process...
The drain is either frozen or plugged...when the freezer coil defrosts the water has no place to get away...
Find and fix the drain and you will be okay again...
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
My Frigidaire is about 5 years old and last week it started leaking water but I cannot tell where it's coming from. When I went to clean the draweres, they were filled with water. Can you tell me what the...
sounds like the freezer defrost drain is frozen up or plugged . It is under the evaporator behind the freezer back panel. I use boiling water to clear and you may have to clear the line at the bottom where it dumps the water in the tray.
2answers
Water leaking from under the freezer
Until defrosting the block of ice you canot see if is a hole or crack in the bottom. But I suppose is leaking from the door gasket under the pressure of the ice inside. Anyway, if you want to keep alife your refrigerator, better unplug it, defrosting and clean it before complete annihilation.
Water is leaking out of the front and back of frigidaire side fre
Clear the bottom of the freezor so you can get at the drain. then get a turkey baster and fill it with hot water. Insert it in the drain in the bottom and squeeze it cleaning the drain. Several applications will solve the problem, and do not forget the refrigerator side as well.
Good Luck,
Gilsh
3helpful
Frigidaire leaking
the drain in the freezer compartment is frozen up you can remove all items from lower freezer and remove access panel on back of freezer compartment pick the ice out of the drain hole with a small screwdriver DO NOT USE SCREWDRIVER AROUND THE ALUMINUM COILS! once all ice is gone that you can see use hairdryer to blow into hole on medium heat. once it looks like it is gone take a small 1/4 plastic tubing and push down the hole to try to clear obstructions then run hot water down hole. if it still doesnt drain take rear access panel off of compressor area (back of refrig) look for drain hose and remove clamp take off and clean u might try this first. but you will have to remove ice from drain.
FRIGIDAIRE FRS22ZRGD2
you may need to clean the drain tube again. the only other place that water may come from is the ice maker if it is over flowing. this however would be very obvious. use some thing like a length of cloths line cable to "snake" the drain after you defrost it. the fastest way to defrost it is to use hot water and a turkey baister. good luck.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
