20 Most Recent Frigidaire FRS26R4C Side by Side Refrigerator Questions & Answers
Freezer not freezing and fridge not cooling
Hi Candi, I am happy to assist you! If your refrigerator is not cooling, it could have floating restriction in the line or something more complicated like an issue with the sealed system that only a professional can repair. This can include the compressor not working, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. It is typically normal to hear the compressor running, humming, or even to be a little warm. However, if you do not hear the compressor at all, I suggest cleaning the unit out including the coils you can reach (typically located in the bottom behind the toe grille) and make sure no food items are blocking any vents in the unit. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues. Best regards!
1/14/2014 3:16:05 PM • Frigidaire... • Answered on Jan 14, 2014
FRS26R4CB0-Freezer not freezing and Fridge not getting Cool
Hi Candi, I don't know this model but most friges are the same, Check on the bottom back, there should be a radiator with a small fan installed. If the fan is not working this maybe your problem, It is not colling the gas. You also may have a gas leak or the gas compressor is not working or starting to work because of a faulty capcacitor.
1/12/2014 12:23:15 AM • Frigidaire... • Answered on Jan 12, 2014
My admiral fridge freezer suddenly stopped working -
I took the time to look up your Model # and you do have the right board. Jazz 14 Should just be a revision one higher than your origional. Describe to me exactly what happens when you try to program it. You may be missing one little step. Make sure you are doing every step exactly right. I too can miss one little confirmation stroke and it seems like it wont work. I Can email you the tech sheet for your model. This will show you how to test all the sensors, and the damper to determine why the FF side is getting too cold. I will also help on my end as much as i can
8/18/2012 12:27:53 PM • Frigidaire... • Answered on Aug 18, 2012
Frigidaire FRS26R4CW1 icemaker not working and food freezes in refrigerator
Contact a tech professional to diagnose the unit. You could have a floating restriction in the coolant lines and cannot easily be found on your own.
8/6/2012 7:53:01 PM • Frigidaire... • Answered on Aug 06, 2012
Freezer is colder not much air blowinginto fridge?
On a sxs refrigerator unit the freezer section actually cools the refrigerator side through a damper door/switch. If the refrigerator section is not cool like it should be, check the damper door for any ice blockages or debris. Clear if you can, yourself and watch it over the next 12-24 hours. If it still is not cooling contact a professional.
8/6/2012 7:35:28 PM • Frigidaire... • Answered on Aug 06, 2012
The freezer motor cuts on and off every 3 seconds
I personally would contact a professional because it could be a faulty compressor/motor or a problem with the communication from the control board.
7/24/2012 5:52:50 PM • Frigidaire... • Answered on Jul 24, 2012
0answers
Frost free quits getting cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
8/23/2011 12:11:44 PM • Frigidaire... • Answered on Aug 23, 2011
0answers
Door will open will not
The door on a refrigerator is an important component to the over all functionality of the refrigerator. A simple refrigerator door repair can potentially save hundreds of dollars in energy every year.
Check the Hinges
A misaligned door hinge can release cold air from inside the refrigerator, causing it to run less efficiently. If the door doesn't shut evenly it could be a problem with a hinge. The easiest repair for this is to simply tighten the screws that hold the hinges. If this doesn't solve the problem try to see if the hinges are level. You may need to replace the hinges all together.
The Door Gasket
The rubber piece that circles the entire door serves a purpose more than just helping the door close quietly. It should form a seal that maintains the temperature inside the refrigerator. If the gasket is cracked or warped you will need to replace this. Find the model number for your refrigerator and you can find the right gasket. Some gaskets are simply put on with adhesives, others require clamps or screws.
The Light
If you have a faulty door switch, the light may stay on in your refrigerator. This wastes valuable energy. To check this simply find the switch and press on it with the door open. Sometimes a thorough cleaning of the switch can fix the problem.
By maintaining your refrigerator door and making the necessary repairs you can save yourself a lot of money in lost energy costs.
I hope this help in solving the problem....
5/8/2011 7:13:04 AM • Frigidaire... • Answered on May 08, 2011
0answers
Frezzer & refrigerator not cooling. Ice build
Leak in system. Made before 1/06. 5yr sealed system warranty. Your manual will tell you.
3/28/2011 4:08:35 PM • Frigidaire... • Answered on Mar 28, 2011
Got new fridge freezer last
4-5. Is fan in freezer section running? Is fan in rear of unit running? Do the sides of unit feel hot to touch? This unit has a problem. Call for warranty service.
3/28/2011 2:27:19 PM • Frigidaire... • Answered on Mar 28, 2011
Can a compressor be replaced without a service
Hi, No, You need special equipment to do this...
Here is a tip that I wrote about how to add refrigerant to a air conditioner orcooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
9/17/2010 2:06:52 AM • Frigidaire... • Answered on Sep 17, 2010
Frigidaire FRS26R4C Side by Side Refrigerator Logo
47 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
freezer colder not much air blowinginto
  • Refrigerators
