SOURCE: Sticker location
please open the bonnet...its either on the front part of the body, very close to the radiator or its in the very back...behind the engine.
cheers
SOURCE: We would like to assemble a Pali Crib - Code 0427
Here is a link for Pali crib with dropside made from 1994 to 2000. Hope this helps. http://www.pali-design.com/docs/Crib98ING-SPA.pdf
SOURCE: Production date for the following Zeiss binocular
There are no recorded serial numbers for Zeiss binoculars made in West Germany or those made by Zeiss after the fall of the berlin wall. The newer numbers have been a mystery to collectors and so far no one has attempted to publish a list. I have newer models with lower serial numbers than older models in my collection.
SOURCE: I want to know the production date of Kenmore
The production date is determined by the SERIAL NUMBER on your appliance. The following link explains:
http://www.fixya.com/support/r2880489-determining_age_whirlpool_appliance
Kenmore washers are manufactured by Whirlpool. If you still have questions, please let me know. I hope this helps you.
Testimonial: "Quick, Easy, and extremely helpful...a big mahalo to jsrock516 for a very definitive answer. "
SOURCE: Just picked up the vacuum - any idea the dates of
The 10 digit serial number on ALL G series Kirbys (G3, G4, G5, G6, Ultimate G, Diamond Edition and Sentria) is engraved into the aluminum on the side of the Kirby, right above where the cloth bag attaches to the machine. This serial number contains the EXACT manufacture date of the machine.
The first number in the serial number will be a 1, 2, 3 or 4 and pertains to the quarter of the year in which the machine was manufactured. The second and third number is the year of manufacture.
FOR EXAMPLE.... in the serial number 1071104984, the machine was manufactured in the first quarter of the year 2007.
The G4 models were manufactured from 1993-96.
My G4 80th Anniversary edition doesn't seem to fit this, however. It's 8941106700. I suspect it's got a replacement handle.
Hello B13Designs,
If you receive a "No Production Server Active" message when using QuickDisc, make sure that the Production Server status is set to Active, Processing orders in Rimage System Manager. Once the Production Server is set to this status, jobs can be processed.
1. Open Rimage System Manager.
2. Select Production Server. Production Server status information displays in the right panel, next to the Production Servericon.
3. If Production Server is paused or stopped, press the play button. Production Server starts.
If this does not fix your problem, feel free to give our support line a call @ 1-800-553-8312 (Option 2).
Thanks!
