20 Most Recent Remington Electric Chain Saw Questions & Answers
throw it away .not worth fixing .
Remington... | Answered on Apr 10, 2019
well if its an electric powered model as the title says it is , then the only oil it should have is Bar/chain oil there should be a little cap just forward to left of the trigger this should be kept full of bar/chain oil for its use
No, the largest electric pole chain saw that can be attached to a pole with the Remington Pole Saw kit, is a 10" saw.
You can go to Master Distributors to find out more detailed info about your situation and speak with one of their reps.
http://www.remingtonchainsaw.com/
Hope you found this very helpful, best regards!
Remington... | Answered on Mar 08, 2018
All I can say is bypass the wiring inside the pole.
Remington... | Answered on Oct 10, 2016
There is a very in depth explanation in this Remington OM.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Remington... | Answered on Nov 26, 2014
Till you get the motor and get the new motor insatlled you will have more into it then a new one...
heatman101
Remington... | Answered on Nov 10, 2014
Dex Online – saw/chainsaw
Chain Saw Sales Inc
386 Broadway Ave, Bedford, OH, 44146
Distance: 10. miles
Egy's Mower & Chain Saw Service
545 Hall Rd, Elyria, OH, 44035
Distance: 24. miles
Stihl dealer locater
Greenes Hardware & Industrial Supply
Full-line Sales & Service Dealer
7734 Broadway Avenue
Cleveland, OH 44105
* * Sill's Motor Sales Company
1901 Brookpark Road
Cleveland, OH 44109
* * Lanphear Supply
* Lanphear Supply
1884 South Green Road
S Euclid, OH 44121
* * Chain Saw Sales
* Chain Saw Sales
386 Broadway Avenue
Bedford, OH 44146
* * North Royalton Power Equipment Co.
10156 Royalton Road
N Royalton, OH 44133
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Remington... | Answered on Oct 28, 2014
Remove the cover, loosen the bolts to allow the bar to slide toward the sprocket. Lift chain off the sprocket and pull out from the notch in the bar. Be sure to turn the chain the same direction, otherwise you will be cutting with the back side of the blades. Slide the new chain blade onto the sprocket then fit into the bar. Once that is accomplished pull the bar firmly outward watching to see that the blade stays inside the slot of the bar. While keeping pressure on the chain and bar, tighten the retaining bolts and replace cover
Remington... | Answered on Oct 01, 2014
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Remington... | Answered on Jul 18, 2014
If you're Remington Pole Saw is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington... | Answered on Apr 16, 2014
They used to be owned by DESA industries. But I beleive that may have changed
Remington... | Answered on Apr 13, 2014
Remington Electric Chain Saw  Logo
368 questions posted
Top Remington Garden Experts
Thomas F. Schneider
roeb
choprboz5
Are you a Remington Garden Expert? Answer questions, earn points and help others
View Most Popular
Remington Garden
  • Remington Garden
Most Popular Question
brushes available remington 106890 02
  • Garden
