20 Most Recent Weed Eater Fl26 Feather Lite Plus String Trimmer Questions & Answers
0answers
HOW TO PUT IN LINE WEED EATER FEATHER LITE PLUS FL26?
You can get a manual from the Weed Eater website.
8/21/2014 1:28:29 AM • Weed Eater Fl26... • Answered on Aug 21, 2014
Feather lite weedeater
Hi Sam... Sounds like you still have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible. Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine. Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT. Note:Before you disassemble the carburetor:Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.That way you will know which way it goes back together when you reassemble it. Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.Check you fuel line condition after a while they will degrade and need replacment. Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc. When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.Be sure to mark the turns down on a piece of paper.That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.Note:The little spring inside of the carburetor goes under the float arm.That is where your fuel inlet needle/float valve is located...on the arm at the end.Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.Once you have your carburetor cleaned/rebuilt that should solve your problem.Please take time to rate me Bud
4/28/2013 10:48:18 PM • Weed Eater Fl26... • Answered on Apr 28, 2013
Weed trimmer (2 wheeled) screeches.
All questions need full 'make model (what is is)' as first 3 words please. Very often, issues like this are a known fault and users tell the fix. You need to track down where the screech is coming from? Wheels Drive Belt Bearings Piston rings Or it may be battery operated? ..
4/24/2024 10:27:50 PM • Garden • Answered 9 hours ago
2answers
Is weed membrane fabric any good for applying to stone driveway
Ensure the membrane is protected with sand before laying the stone to avoid piercing the membrane.
4/24/2024 11:53:02 AM • Garden • Answered 20 hours ago
0answers
Parts diagram for wall kennel pro model 8800
It looks like you meant 'Wahl', this is why upper case letters are important for 'proper names' because Spell check won't alter them. Here are the parts diagram and suppliers, including Wahl themselves. https://www.google.com/search?q=wahl+kennel+pro+model+8800+parts+diagram You can safely ignore the answer from the African Prince as he is just copying and pasting from AI Chat GPT4. ..
4/23/2024 9:17:53 PM • Garden • Answered Yesterday
I've a 5 litre garden pressure sprayer and it's not functioning properly. It is pumping pressure but then it's leaking it all out at top of the green handle.
Here are some steps you can follow: Check the Seals and O-Rings: Release the pressure: Make sure there's no pressure in the cylinder by releasing the pressure release valve. Unscrew the pump: Remove the pump to access the internal components. Inspect the seals and O-rings: Look for any damaged or worn-out rubber seals. Check the rubber seal at the bottom of the tube (where the plunger sits) and ensure it's in place. Examine the one-way valve (usually at the bottom of the tube) and clean it. Lubricate it with silicone grease. Lubricate the rubber washer on the plunger with silicone grease and reassemble it in the tube. Reassemble the pump: Put the plunger back into the tube and lock it with the handle. Test the sprayer: Pump it up and check if it maintains pressure without leaking. Inspect the Handle and Hose: Handle connection: Ensure the handle is securely attached to the cylinder. Hose inspection: Check the hose for kinks, twists, or blockages. Straighten out any kinks and remove debris that might be blocking the hose. Check the Nozzle and Wand: Nozzle adjustment: Adjust the nozzle to the desired spray pattern. Wand inspection: Examine the spray wand for clogs or obstructions. Lubricate O-Rings and Seals: Apply silicone grease to the O-rings, seals, and other moving parts to ensure smooth operation. Test the Sprayer: Fill the cylinder to the desired level (avoid exceeding the maximum fill mark). Screw down the pump firmly to create an airtight seal. Manually operate the pressure release valve to ensure it's working.
4/23/2024 5:45:51 PM • Garden • Answered Yesterday
2answers
What are the top advantages of online flower delivery services?
As a customer, the advantage is that I don't have to drive to the florist. Saves time and gas. I could make a phone call, but then I wouldn't see the available flowers.
4/23/2024 10:14:23 AM • Garden • Answered Yesterday
What is the transportation ring on a huskvarna chain saw
The transportation ring on a Husqvarna chainsaw is a small metal ring that is sometimes fitted onto one of the bolts when the saw is new. Its purpose is to prevent the chain from rotating during transportation or storage. If your chainsaw has this ring, you should remove it before using the saw. Keep it in a safe place so you can use it again if needed. If you're looking for more information about Husqvarna chainsaws, you can refer to the operator's manual for detailed instructions. https://www.manualslib.com/manual/3145215/Husqvarna-440.html
4/20/2024 9:45:09 PM • Garden • Answered on Apr 20, 2024
HPB18 3.6Ah 18Volt Replacement for Black and Decker 18V Battery can this stay on the charging unit in between use?
Yes, you can leave it on the charger. Modern chargers are designed to handle this, and it won’t harm the battery. However, it’s a good practice to remove the battery once it’s fully charged to prevent overcharging, especially if you won’t be using the tool for an extended period.
Remember to follow the manufacturer’s guidelines for optimal battery care, and enjoy the enhanced performance of your Black and Decker tools!
4/19/2024 6:17:32 PM • Garden • Answered on Apr 19, 2024
What are some broadleaf evergreen weeping trees?
TreeKisan is a AI- based Platform where tree farmers can know the standing tree market valuation in just 1 minute and sell to potential buyers. Easily assess the economic potential of your trees and make informed decisions. Download TreeKisan Now!
4/17/2024 9:39:10 AM • Garden • Answered on Apr 17, 2024
How do I found out the valve clearance for a 14.5 I/C OHV. Model 280H07?
Link : https://heavy-equipmentmanual.com/
4/9/2024 7:22:44 AM • Garden • Answered on Apr 09, 2024
4answers
Do I have to prime a 1530 John deer tractor after i replaced the fuel pump?
Yes, use instructions for bleeding after a filter change. See attached.
If primer lever stroke action seems short, bump the starter so the pump cam rotates away from the pump.
4/5/2024 1:18:46 PM • Garden • Answered on Apr 05, 2024
2answers
Strimmer line breaks after a few yards use
buy better line. and chain link fences are ******* lines
4/3/2024 12:50:54 PM • Garden • Answered on Apr 03, 2024
Scotts lawn mower 21995x8b manual
I'm guessing you have fixed this or given up after 13.5 years, but here is my suggestion for the next person who has this trouble. If you ran it out of fuel and left it over the winter, it could have a drop of fuel that hardened and plugged one of the fuel ports in the carburetor. I have had this happen and needed to remove the fuel bowl and poke the dried film with a pin. Put it back together and it started right up.
3/31/2024 1:19:11 AM • Garden • Answered on Mar 31, 2024
Weed Eater Fl26 Feather Lite Plus String Trimmer Logo
6 questions posted
Top Weed Eater Garden Experts
Jay Finke
Jay Finke
john h
Are you a Weed Eater Garden Expert? Answer questions, earn points and help others
View Most Popular
Weed Eater Garden
  • Weed Eater Garden
Most Popular Question
put in line weed eater feather lite plus
  • Garden
