20 Most Recent Craftsman 25cc Gas Line Trimmer Questions & Answers
Hi
DJ8J champion would be suitable.cheers
Craftsman 25cc... | Answered on Jun 05, 2019
Sounds like bad seals buy some stop leak and add to your oil and see if that helps
Craftsman 25cc... | Answered on Jul 13, 2018
air vent in gas cap pluged, push a pin through it
Craftsman 25cc... | Answered on May 29, 2018
When the Craftsman Weedwacker starts in idle and then stalls and the primer bulb will not fill with gasoline or will not pop back after being pushed in, then you have a blockage within the carburetor. The bulb is intended to **** fuel into the supply line, to prime it. To solve the problem, remove the carburetor, open the side that has ONE screw holding it (not the side with four small screws), remove all the two lines remembering how they were attached (the feeder line from the fuel tank attaches to the straight copper tube and the tube going to the bulb intake side attaches to the bent copper tube) and blow out the material blocking the fuel flow inside the carburetor. Then after replacing the carburetor, press the bulb and it should **** and discharge fuel easly. I have had two of these and the fuel path within the carburetor clogs easly. Jim Hart
Craftsman 25cc... | Answered on May 20, 2018
fit a diaphragm kit in the carby
the pump diaphragm is the first to fail and then the float diaphragm distorts and will not let in enough fuel to keep it running
Craftsman 25cc... | Answered on Jan 10, 2018
Check with Sears Parts direct.com they will let you download a owners manual or talk to a pro.
Craftsman 25cc... | Answered on Dec 25, 2017
My Yard Works was set at the factory to run with the choke partially on. They said it has something to do with the air pressure where we live. Otherwise if it has to have the choke on full then there should be a screw to set it so it will run with the proper setting
Craftsman 25cc... | Answered on Dec 17, 2017
If it is like other trimmers there is a hole on the top side of the head put a small screwdriver in that hole it will stop the head from turning unscrew the head counterclock wise.
Craftsman 25cc... | Answered on Dec 14, 2017
Sounds like the carb is getting clogged. Drain the old fuel and make sure the fuel filter is attached to the fuel hose inside the fuel tank. SeaFoam or a product called Start will sometimes clean the carburetor. If not, you will need to have the carb rebuilt, flushed or replaced.
Also, check your muffler and spark arrest, sometimes if they are clogged, you will have a similar issue.
Craftsman 25cc... | Answered on Nov 20, 2017
there should be 4 bolts holding the pull rope and spring to the motor if you need more info. go to Sears Parts.;co.com
Craftsman 25cc... | Answered on Sep 10, 2017
You probably have a bad hose or a bad hose connection that is sucking mostly air instead of delivering full fuel to the carburetor!
Craftsman 25cc... | Answered on Apr 19, 2017
For two stroke engines of this capacity the ratio of fuel to two stroke oil is (25:1) 25 fuel to 1 (two stroke) oil. Eg 200 ml of two stroke oil to 5 litres of fuel.
Craftsman 25cc... | Answered on Jul 18, 2016
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
there should be a retaining C Clip that will need to be removed from the shaft look closely!
Craftsman 25cc... | Answered on May 12, 2016
In the middle of the drum is usually a small torx screw... I put pull cord rope inside where the plug goes to stop the piston from moving as I'm unscrewing it..
Craftsman 25cc... | Answered on Oct 28, 2015
I had the same problem. If you replace the lines and you get them swapped, it just won't run. Nothing will be damaged. So then just swap them around. There are only two choices. Trial and error worked for me!
Craftsman 25cc... | Answered on Sep 16, 2015
Craftsman 25cc Gas Line Trimmer Logo
914 questions posted
Top Craftsman Garden Experts
john h
lnbn1975
Jay Finke
Jay Finke
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
cutter spins freely
  • Garden
