20 Most Recent
Briggs & Stratton Prosumer 2800 PSI (Gas - Cold Water) Pressure Washer - 20324 Questions & Answers
When adding SAE 30 oil to new pw, do we add to the
From what i've read in the manual you need to fill both the pump and the motor. The pump itself will have a dipstick, the motor gets filled to the top. If the motor has two inlets one should fill up when you pour in the other side. Most briggs had two motor oil inlets so the motor could be used on several types of equipment. The pump itself should use about 9.6 oz
7/3/2018 3:47:04 AM •
Briggs &...
Answered
on Jul 03, 2018
Briggs & stratton 17.5 hp has fuel, spark and good air filter no start.
Likely either the engine is flooded or low compression.
A simple go no go compression test is remove spark plug and press a thumb or finger firmly over the plug hole and crank engine. It should forcibly push your finger and make a loud PFFfft sound. No or little sound equals insufficient compression.
If the push rod was not bent, there was no reason to replace. If it was bent then I question how you set proper valve lash with new pushrod as the typical cause for a bent rod is a displaced valve guide.
If compression is OK then likely it's simply flooding and you have a carb float/inlet needle issue. Crank engine, remove plug and if it's saturated with fuel then it's flooded and a flooded engine will not fire, even with starter fluid.
Comment for further assistance.
11/6/2023 1:03:20 AM •
Briggs &...
Answered
on Nov 06, 2023
Briggs & Stratton 450 series 148cc. How to get higher revs?
Remove and sharpen the blade. If the blade is sharp, it will slice though the grass with no resistance. Over time, the cutting edge gets blunted by stones, grass and soil. If that doesn't fix it, remove the carburetor, strip and clean all the jets. Make sure you count the turns and write down any pilot jet settings.
5/13/2023 3:30:01 AM •
Briggs &...
Answered
on May 13, 2023
What kind of oil in a22 ton briggs & stratton motor
BRIGGS & STRATTON ENGINES:
For temperatures above 40? F use an SAE30W oil. Using multigrade oil may increase oil consumption. Using SAE 30W oil below 40? F will result in hard starting and possible engine
bore damage. For temperatures below 40 ? F use
an SAE10W-30 or SAE5W-30 oil. Oil capacity for the 6 H.P. engine is approximately 5/8 quart (20 ounces; 0.6 liter).
Refer to Briggs & Stratton engine owner's manual for additional
information.
11/23/2022 5:27:28 PM •
Briggs &...
Answered
on Nov 23, 2022
How to adjust valves on briggs and stratton 17.5
Remove spark plug
Remove cover from engine that covers the flywheel
Remove rockerarm cover or valve cover
Find TDC (top dead center) by rotating the flywheel by hand and your finger over the spark plug hole as you rotate the flywheel you will feel pressure against you finger at some point then stop.
This is the compression stroke it is called now find a long slim round piece of plastic or plastic ink pen to stick in the spark plug hole (If you are careful a slim screwdriver can be used ) and find the piston top, then slowly rotate flywheel again (cw) as the piston is moving up pushing the plastic up as you rotate the flywheel slowly.
a max. piston up or tdc as you turn you will feel and then the piston starts to go the other way,at that transition this is tdc (piston is on top of stroke) leave it there,,both valves should be closed at that point.
Have a feeler gauge and set the exhaust valve at a loose .002 and the intake a loose .004 be sure engine is cold when valves are adjusted
Feeler gauge goes in between the rocker arm tip and valve stem top for each valve setting.
Note the rocker adjustment at the push rod side of each valve by tightening and loosening to make adjustments,lock your adjustments in place and rotate flywheel a few times and recheck settings
7/2/2022 5:20:55 PM •
Briggs &...
Answered
on Jul 02, 2022
