SOURCE: Line space
If you're talking about Word 2007, it is in the 'Paragraph' box under the 'Home' tab, between 'Justify' on the left and 'Shading' on the right.
SOURCE: Lines on copies
I am having a similar problem, there's dark lines on the left side of my copies. It doesn't matter if it's on the glass or not. I also think that the lines are getting bigger and darker over time.
SOURCE: evenly spaced vertical lines
Hello
Check the smoothing capacitor to video output supply voltage, usually derived from any one winding of the LOT. It will come around 10uF350VDC to 47uF 350VDC range. If this capacitor is faulty, or gone less in capacitance with time, this type of fault will occur. Check the green volour output transistor on the video output card, can be located attached to the neck of the picture tube; for any loose soldering or leakage. OK.
SOURCE: JVC 36" color sterio tv lines on top of screen
does the problem occur while watching dvds. it is possible that it is an issue with your tv but i would try switching off of cable to a game console or dvd before i said for sure it was the tv. you also might try using another port on your tv such as hdmi, s video, rca or componet ports . if any of those ports work i would replace my cable from the cable outlet.
