20 Most Recent Janome Hello Kitty 11706 Mechanical Sewing Machine Questions & Answers
Handwheel stuck
most likely the bobbin thread is wound around the components. remove the bobbin and check for a mass of thread cut it all away and remove every last bit then it should work
7/11/2019 6:24:23 AM • Janome Hello... • Answered on Jul 11, 2019
My Babylock 6150 fell over and the spool pin
You may be able to (very carefully) super glue the pin back on where it broke off.
2/1/2018 7:55:01 PM • Janome Hello... • Answered on Feb 01, 2018
2answers
Fabric feeding, then jamming
Hi, If you are getting loops on the bottom side of your fabric then it is a TOP tension problem, usually the thread is not between the tension discs. Here is a simple check: Thread the upper path and stop short of the eye of the needle. Drop the presser foot. Now if you pull on the thread you should feel the drag of the tension discs. Increasing the tension setting should make it harder to pull. Now while your pulling raise the presser foot. All tension should be gone and the thread will pull thru easily. I have worked on a few Hello Kitty machines and usually there is a single screw to remove the nose cover, exposing the needle bar and slack arm assembly. The slack arm does just that, it takes up the loop and the tension discs keep it from pulling more thread off the spool. Look for some thread wrapped up in the mechanism and clear it if you can. This is were I find most of the problems Good luck!
4/2/2017 4:35:59 PM • Janome Hello... • Answered on Apr 02, 2017
2answers
Lost manual to Hello Kitty sewing machine made by Janome
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link tothem:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
12/28/2015 4:22:24 PM • Janome Hello... • Answered on Dec 28, 2015
2answers
How can I open the Janome Sewing Pretty with Hello Kitty machine to put in bobbin?
There is a removable tray on the front. Pull it to the left. This will expose the bobbin door. Lift the clip on the bobbin case to remove and replace it on the hook.
3/7/2015 11:08:44 PM • Janome Hello... • Answered on Mar 07, 2015
Does sewing pretty have capability of sewing in zippers
This is a very basic model, and is more for minor repairs than actual sewing. If the foot doesn't just clip on, then it wasn't meant for a zipper foot.
3/5/2015 8:16:30 AM • Janome Hello... • Answered on Mar 05, 2015
4answers
Why does the needle keeps getting stuck in the bobbin
Sounds like you've got a thread jam going on. Take the bobbin and bobbin case out, take the needle plate (=throat plate) off the machine, and clean all the lint and bits of thread and other gunge out of there. Reassemble. Rethread with the presser foot up. Fetch up the bobbin thread and pull bobbin and top thread ends under and behind the presser foot. Then start each seam like this: 1. Fabric under the presser foot; lower needle with handwheel or needle up/down key into the beginning of the seam. 2. Drop the presser foot. 3. Hold the ends of the bobbin and top thread behind the presser foot while you take the first 2-3 stitches 4. Drop the thread ends and sew normally. See also the last pair of photos here: http://www.picturetrail.com/sfx/album/view/22521551
5/22/2014 9:10:32 AM • Janome Hello... • Answered on May 22, 2014
Why does the needle stop and get stuck after sewing for a short time
Try to use proper needle.
2/10/2014 10:27:57 AM • Janome Hello... • Answered on Feb 10, 2014
Needle Jammed
Please check the timing. And you go to mechanic shop or you ask the experience tailors.
1/31/2014 4:14:46 AM • Janome Hello... • Answered on Jan 31, 2014
Machine manual
Is a basic zig zag threading system, if you do not have a user manual you can refer in utube for instruction video on threading a sewing machine.
12/24/2013 7:54:43 AM • Janome Hello... • Answered on Dec 24, 2013
I would like to get
Don't fall for those rip-off sites that try to sell you manuals, when the legit company's customer service will send you the proper pdf for free. Martin Lloyd above is totally wrong in saying "it's not .. free". I just got my jem lite manual from their friendly & responsive customer service today:custrel [at] janome-america.com. (replace the [at] with the proper symbol.)
10/28/2013 5:27:31 PM • Janome Hello... • Answered on Oct 28, 2013
0answers
2answers
Hi, I didn't get a
Hi
I can usually find manuals on Janome no problem but I can't access the one for Hello Kitty.
If you click on the specifications for any machine on the Janome site a PDF appears with a download manual button next to it. I can see the PDF but no download manual button.
http://www.janome.com/index.cfm/Machines/Sewing-Quilting/Hello_Kitty
This machine does look similar and I could get the link for a free manual, hope this helps. If not contact Janome.
http://www.janome.com/documents/File/ManualFile/3128.pdf
3/29/2013 6:07:01 AM • Janome Hello... • Answered on Mar 29, 2013
What size bobbin is used in the Hello Kitty
www.youtube.com/watch?v=ntED0usTklEon this youtube video it is shown how to work the bobbinsgoodluckkolbrun
3/7/2012 8:32:45 PM • Janome Hello... • Answered on Mar 07, 2012
How can I get a manual for this machine?
http://content.janome.com/documents/File/ManualFile/Inst%20book%20Hello%20Kitty%203Q%20(EnFrSp).pdf
2/19/2012 7:58:45 AM • Janome Hello... • Answered on Feb 19, 2012
Instruction manual
There is a free manual for the chainstitch Hello Kitty which may, or may not help. try here. http://www.nkok.com/FCKFiles/File/4303%20Lockstitch%20Manual%20&%20Project.pdfOther than that you may need to buy a manual from some of the online sewing machine manual sellers
12/24/2011 3:29:00 PM • Janome Hello... • Answered on Dec 24, 2011
Janome Hello Kitty 11706 Mechanical Sewing Machine Logo
62 questions posted
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Sewing Machines
Most Popular Question
like get
  • Sewing Machines
