20 Most Recent Janome Memory Craft 200E Embroidery Machines Questions & Answers
Hi you should be able to do this in the edit screen if you hoop size can fit both designs.
Janome Memory... | Answered on Mar 04, 2019
You would have better luck searching on facebook to find this out. You can also check on yahoo groups by searching groups for that model of sewing machine. Good Luck
Janome Memory... | Answered on Aug 27, 2014
I suspect the bobbin thread has escaped its tension spring. If you give the bobbin thread a quick short tug and the bobbin spool spins then likely the thread is not behind the tension spring. This usually causes hook jam but not always.
First be sure you have threaded per machine instructions... see below.
Next turn handwheel and position needle at the high point of stroke (always when loading bobbin). Remove and re-insert bobbin. Now, to be sure the bobbin thread is fully positioned behind the tension spring, before you move the bobbin thread into the notch, place your right index finger on top of the bobbin spool to prevent the bobbin spool from turning. Hold thread snugly (in slight tension) as you move it towards the back of the notch. You should feel the thread slide in place behind the spring. Let loose the spool and lightly pull thread. Note the resulting change in tension. (don't forget to set top thread tension back to a more normal setting)
Comment here if you require further assistance.
If you need... your manual may be downloaded at no charge from the Janome site.
https://www.janome.com/siteassets/support/manuals/embroidery-models/inst-book-mc350e.pdf
Janome Sewing... | Answered on Apr 14, 2019
I searched the internet using https://www.google.comI only saw parts for that model number. Could it be named New Home in order to search or request manuals?I saw a youtube video for a different model showing a technician carefully opening a machine to repair a similar problem. It warns you to disconnect electric power before servicing.https://www.youtube.com/watch?v=xHcEJYDo12k
https://www.sewingmachinesplus.com/janome-manuals.php
You tried disconnecting the stitch regulator?
No, try machine without regulator.
Yes, make sure you have power at the wall socket. Unplug sewing machine and plug in a lamp, radio, or vacuum to test for power. If power at wall socket, then plug sewing machine back in to wall socket. If still no power, disconnect and reconnect power cord at machine end. If still no power, try cycling the sewing machine ON/OFF switch a few times.
If still no power then likely the internal fuse or other.
https://www.manualslib.com/manual/1231564/Janome-1600p.html?page=16#manual
Janome Sewing... | Answered on Apr 11, 2019
PERHAPS AT A SHOP THAT SELLS JANOME MACHINES
Janome Sewing... | Answered on Apr 10, 2019
SAD TO SAY CAN NOT SAY AS I HAVE THE OLD KIND THAT SAY NOTHING JUST SEW WHEN I WANT THEM TO
Janome Sewing... | Answered on Apr 07, 2019
Janome Memory Craft 200E Embroidery Machines Logo
7 questions posted
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Janome Sewing Machines
Most Popular Question
janome 200e 6 files each lile goes
  • Sewing Machines
