20 Most Recent PfaFF Creative 7570 Questions & Answers
The only hoop that I know is compatible with the Creative 7570 is the Creative Deluxe Hoop, part number 412944502. See the compatible accessories, hoops here: http://www.pfaff.com/en-US/Accessories#.99.62 . I've found this hoop in stock here: https://www.performancesewing.com/partsdatabase/embroidery-hoops/pfaff-deluxe-hoop-360x200mm.htm and here: https://www.peddlersway.com/shop/c/p/Creative-Deluxe-Hoop-360x200-x1994405.htm .
I hope this helps.
PfaFF Creative... | Answered on May 16, 2019
See
Pfaff creative 7570 Manual
https://www.manualowl.com/p/Pfaff/creative-7570/Manual/184474
Manuals and user guide free PDF downloads for Pfaff creative 7570.
PfaFF Creative... | Answered on Feb 27, 2019
is your service shop a certified pfaff scervice center? if not take it to one. your part is still available brand new from pfaff.
PfaFF Creative... | Answered on Feb 26, 2019
These folks are a great help, and being the folks whom built the machine will be the most qualified to access your issue.
PfaFF Creative... | Answered on Dec 25, 2018
The 7550 has a battery backup (little door on bottom of machine - 2 AA batteries). Remove batteries for a couple of days and the code should disappear. Removing the batteries WILL NOT effect the main memory of the machine - they are just for the backup of any personally designed stitches and memory combinations - not the hard memory of the machine. Periodically these batteries will need to be changed - a message will pop up on the screen to let you know.
Hope this helps (ex-Pfaff employee - GREAT MACHINE!)
PfaFF Creative... | Answered on Dec 21, 2018
Hi Carolyn,
Look for a small turning wheel, just below the green and pink selection knobs, on the front right of your machine. Turn it anticlock wise for a darker image and clockwise for a lighter image. Enjoy!
PfaFF Creative... | Answered on Jun 02, 2018
hay guy,
i also need the diagrams.i tryed many way to find it.but it dosent work.
anyway im repairing efka & quick rotan by myself without any diagrams.
if you like i can share my knowledge with you.
email me .
first sms me .00940772532280
nuwan
PfaFF Creative... | Answered on Feb 02, 2018
Try turning the machine off, removing the unit and then placing it back before turning the power on again.
PfaFF Creative... | Answered on Jan 20, 2018
silicon or electricial contact cleaner might work
PfaFF Creative... | Answered on Jan 08, 2018
Dealing with electricity, it may be best to take it for service.
PfaFF Creative... | Answered on Jan 05, 2018
The top is also attached with some clips to the front and back of the machine. The handle also needs to be removed after you loosen up the top. It is held on with some C clips. The best way to remove thread is to separate the needle bar from the upper shaft. This may require some experience to get it back into adjustment. Good luck if you try this on your own.
PfaFF Creative... | Answered on Nov 26, 2017
happy sewing
http://www.cyberport.net/users/milnerwm/FAQ.html
PfaFF Creative... | Answered on Nov 18, 2017
I can't tell you much or offer any advice but I can tell you with absolute certainty the Windows 7 compatibility programme has never worked for me.
I have stuff I used to use with XP and either it works with 7 or it doesn't and if it doesn't the compatibility programme makes not a jot of difference.
PfaFF Creative... | Answered on Nov 11, 2017
hi there not sure if the manual will help but if you go to this link you might find it.
pfaff 7570 manual Google Search
or go to this link might help you to find out why.
pfaff 7570 presser foot wont go down Google Search
PfaFF Creative... | Answered on Nov 04, 2017
This little video should help you https://youtu.be/VOxVVcZhH3w
PfaFF Creative... | Answered on Sep 29, 2017
First, make sure your batteries are new, and not cheap ones. Change them again if you are in doubt. Try pressing ANY two buttons as an experiment. If this fails I can't help, but try another dealer, preferably ask to speak to their repair man. Good luck !
PfaFF Creative... | Answered on Sep 05, 2017
Sewing Machines Logo
739 questions posted
Top PfaFF Sewing Machines Experts
Douglas Plant
Douglas Plant
MissFixIt828
Level 1 Expert
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • PfaFF Sewing Machines
Most Popular Question
pfaff 7570 blank green screen when
  • Sewing Machines
