SOURCE: dvd picture is darker than tv picture
Most sets have electronic service adjustments. Contact manufacture for nearest service center.
SOURCE: I have a 32 inch Proscan LCD tv. Is there any way
I found this solution on the PROSCAN website. www.oncorpus.com.In the customer support section, under manuals for you model of television. I hope this information helps you with your problem. Press MENU on the front panel or on the remote control and then use the up and down arrows to select the AUDIO menu.Press the enter button to enter the function.
1. Use the up and down arrows to select what you want to adjust in the AUDIO menu.
2. Press ENTER button to select it and then use the right and left arrows to adjust
3. When you are satisfied with your adjustment, press MENU to exit the main menu.
Audio Mode.
SOURCE: Proscan 32'' VGA port; TV says not supported on VGA input
Sounds like your resolution on your computer is set too high for your tv to accept. Try putting your computer resolution down to 1024x768 or lower and see if that works.
SOURCE: how do I hook up a DVD player to a proscan 32 inch
to connect your TV to your DVD, you will be needing a RCA wire (Yellow, white and Red wire). The yellow stands for video (visual/display), while the read and white stands for audio (sound).
Look at the back of your DVD, look out for Video Out, connect the yellow wire there. Also look out for Audio Out L & R, connect the white and red wire there.
Then turn the back of your TV, you will find Video, and Audio IN, Connect the other part of the wires from the DVD to the DVD, that is, Video for video and audio for audio.
Once you have connected the wires, turn on your TV, and your DVD player, press source on your TV remote to AV, and you will see your DVD displaying on your TV.
That's to hook up your DVD to your TV. Follow instructions carefully and you won't have any problem.
Good luck.
