20 Most Recent
Proscan PS27500 27" TV Questions & Answers
TV won't turn on
My TV won't power on either with the remote or with the manual power on. I hear a clicking noise and it appears that the TV is turning on and off. After several times it stops. Never actually see a picture.
Cable won't work
Channel tuning capability to your set might be 98. If so, nothing can be done.
42 inch sharp tv wont turn on no red light
check blown fuse at the power supply board.but before you replaced it with new one a component testing must be applied. check for a bad parts at the power supply section.
Mitsubisi tv makes clicking sound to come on and then goes right back off
Visit the site named 'Electro-help' for
more details. Check this link and
select the site named above. View it
in 'Flip card' option, which can
be selected from the drop down box menu by the [Sidebar] tag, at the top left
corner of the display window. It will
make search easy. Some times, the ads
attached with each posts, both at the right and bottom, might help you to find
the availability of spare parts. There
are more than 750 posts to different brand TVs now.
I am trying to hook
Hello! This is Dan with DISH Network Customer Service. Have you tried channel 60 or 73?
I have a mitsubishi wont turn on clicking noise
is the mitsu tv a crt(picture tube type) or lcd/plasma. If it's the later it could be worth the repair, if it 's a crt type tv it might be that some parts will not be available, but in order to find out you'll need a better description of the type of tv , the size of screen and a better detail of what the problewm sounds like. Another thing that may persuade you to making the decision on wheter to fix or not is how familiar are you with electronic replacement, like desoldering and soldering technics and or location of circuits once you open the tv. Hope this helps
LCD Model No 32723HD switching fault
found the problem i turnt the tv on and once the fault appeard i used a freezer spray on the chips it turnt out to be the main chip . i then put some heat sink paste on it and took a hink sink and fan off a comp graphics card and fixed that to it to help keep it cool but going to get a new board as i know this was only a temp fix ( new board £59.00 )
My flat screen tv dont turn on
Hey,
My TV had the same problem. From my experience try when turning the TV on changing the TV channel on the TV not the remote.
