20 Most Recent
Proscan PS27113 TV Questions & Answers
CODE FOR RCA XL100
use the search button on the remote with the tv on.. wait until you are able to turn it off with the remote..
TV does not work with
No,if ur tv is hookup to pay cable or or pay satalite dishes or Verizon FIO or ATT U VERSE signals.
Tv will not turn on
Take all connection out (remove from electricity), turn the router off, After ca 2-3 minutes connect all connections and the router. Check that all connections are in the right place. (scart connections have a way of not being properly connected)
Good luck
this usually works for me you can also move the batteries around.
kollagunn
Cant get picture or sound...Proscan 27113
You can tune to 90 for input 1 S-video, 91 for input 1 composite and 92 for input 2 composite only.
Most RCA and GE brand replacement remotes will work using code 000, or 001. I use code 237 for my 5 in 1 remote and can get PIP and the setup displays to work.
tom
Need the two 3 inch home theater speakers
Connect a set of bookshelf speakers to the red/black connectors on the backside of the set, and switch to 'external speakers'. A lot easier than trying to find the originals.
tom
Rca ps27113 tv will not power up
Good day.
Try to check for the prescence of 160volts along the secondary output. Also check H out transistor and likewise, loose contacts along the chroma ic
Regards,
mycho
My tv is blinking a blue light when I try to turn it on along with a popping sound.
It sounds like there may be an issue with the power supply or internal components of your Proscan PLDED5030A-RK TV. The blinking blue light and popping sound could indicate a malfunction that is preventing the TV from turning on properly.
Here are a few steps you can try to troubleshoot the issue:
1. Unplug the TV from the power outlet and leave it unplugged for at least 10-15 minutes. This can help reset the internal components of the TV.
2. Check the power cord and connections to ensure they are secure and not damaged. If there are any visible signs of damage, such as frayed wires, replace the power cord.
3. Try plugging the TV into a different power outlet to see if the issue persists. This can help determine if the problem is with the power source.
4. If the issue continues, it may be necessary to contact a professional technician or the manufacturer for further assistance. They can diagnose the problem and recommend the appropriate repairs.
It's important to exercise caution when dealing with electronic devices, especially when there are signs of malfunction such as unusual sounds or lights. If you are unsure or uncomfortable with troubleshooting the issue yourself, it's best to seek help from a qualified professional.
3/22/2024 11:46:39 AM •
Proscan...
Answered
on Mar 22, 2024
