20 Most Recent Proscan 32LA30Q Television Questions & Answers
2answers
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
4/7/2020 12:30:31 AM • Proscan 32LA30Q... • Answered on Apr 07, 2020
0answers
Proscan tv powers on but no picture
Does the audio still work normally? If so uits most likely the inverter board which has failed and you can get a replacement inverter from www.tvcircuitboards.com
11/26/2017 3:39:05 PM • Proscan 32LA30Q... • Answered on Nov 26, 2017
Need codes for proscan
phone_header_def.png saveupto_a.png phone_callnow_def.png DIRECTV Specials DIRECTV Packages DIRECTV Receivers DIRECTV DVR DIRECTV HD DIRECTV vs. Cable DIRECTV vs. Dish DIRECTV Sports Home > Remote Codes DIRECTV Remote Codes remote_codes_header.jpg TV CODES VCR CODES DVD CODES STEREO RECEIVER CODES
STEREO AMPLIFIER CODES DIRECTV RECEIVER CODES
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
11/22/2016 5:12:55 PM • Proscan 32LA30Q... • Answered on Nov 22, 2016
11answers
Proscan Tv is humming
This made my humming sound go away completely;
From JD at oncorpus.com [manufacturer of the 32LB30Q]
Please follow these instructions, should fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone.
John
11/11/2016 6:23:42 AM • Proscan 32LA30Q... • Answered on Nov 11, 2016
How can I set TV channels to scan for TV to work?
Go to menu. Then channel or tuner. Should have option to auto scan
9/11/2016 4:37:23 PM • Proscan 32LA30Q... • Answered on Sep 11, 2016
How do i fix a proscan tv to turn, only a red and blue light are on
Well without actually opening it up and determining where the problem is, it's unlikely you will get it to come back on. I suspect something wrong with the power supply but it could be something else also.
3/3/2015 2:52:43 AM • Proscan 32LA30Q... • Answered on Mar 03, 2015
Manual for plcd3213a
go to www.proscanvideo.com
2/22/2015 3:35:40 AM • Proscan 32LA30Q... • Answered on Feb 22, 2015
Proscan inverter board won't power o, Any ideas?
hi travis, you din't mention what happened after you disconnected the main board. unplug and plug is not bypassing.to bypass the main board you have to keep it disconnected.if the back lights come on and stay on after main board disconnected, the main board is defective. good luck.
2/16/2015 3:56:00 PM • Proscan 32LA30Q... • Answered on Feb 16, 2015
2answers
The power supply in my Proscan TV 32 inch is dead.I got a new power supply the only differences between the old one & new is 2 ADDED capacitors other than that there identical should I remove the 2 ca
Turn it on and see if it works fine! If not, please report back! you should not remove the capacitors if you are not facing any issue!
2/15/2015 4:36:42 PM • Proscan 32LA30Q... • Answered on Feb 15, 2015
2answers
I replaced all the capacitors on my 32in pro scan tv but it still will not turn on...the power light indicator is blue when powered up but no sound nor picture
The unit is too old now. You wasted money for noting. Trash the TV and go for a new system.
2/3/2015 9:24:04 PM • Proscan 32LA30Q... • Answered on Feb 03, 2015
2answers
Can i hook pioneer speakers from a system to my lg flat screen
Absolutely! To provide a better solution to your problem, however, you will need to provide model numbers of your TV and surround sound system. Depending on the available hookups and your hardware, you may need a received to make everything compatible.
1/11/2015 12:05:12 PM • Proscan 32LA30Q... • Answered on Jan 11, 2015
11answers
Lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
10/5/2014 10:40:23 PM • Proscan 32LA30Q... • Answered on Oct 05, 2014
Power had went out for about three hours when it came back on proscan tv had no picture and buttons on side do not work
Do a reset to this set, and try again. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
9/4/2014 9:13:53 AM • Proscan 32LA30Q... • Answered on Sep 04, 2014
How do i fix the wrinkles in the screen
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
8/15/2014 4:55:01 AM • Proscan 32LA30Q... • Answered on Aug 15, 2014
My proscan tv model 32LA30Q has red light when it's off...turn it on i get the blue light but it shows a blank screen no sound....sometimes i'll leave it on for an hour or 2 turn it off and turn it on
Sounds like the main power regulator board [SMPS] itself. Check for any loose solder terminals at this board. Contact any service technician to assist. Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Do asearch by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis.
7/24/2014 2:34:11 AM • Proscan 32LA30Q... • Answered on Jul 24, 2014
How do i fix my tv from flashing colors?
If the voltage output from the main power regulator board is abnormal, this kind of fault can occur to LCD TVs. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
7/22/2014 6:25:56 PM • Proscan 32LA30Q... • Answered on Jul 22, 2014
Tv went blank but sound is there
Back-light fault. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
7/7/2014 3:50:18 AM • Proscan 32LA30Q... • Answered on Jul 07, 2014
Proscan 32LA30Q Television Logo
272 questions posted
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proscan Televison & Video
Most Popular Question
power supply in proscan tv 32 inch dead
  • Televison & Video
