20 Most Recent Proscan 32LB30QD 32 in. LCD TV Questions & Answers
How do i turn of the word caption on my proscan tv
Turn "closed captioning" off in your menu under display settings, if it's not there it's under "sound settings". Thanks & have a great day! 2dc0ea44-3fd3-471a-b079-850b09fbf794-nncoads5rrxqow0euxlbnu42-4-0.jpeg
2/27/2023 6:05:56 PM • Proscan 32LB30QD... • Answered on Feb 27, 2023
2answers
We have a proscan Model 26LB30QD. Does this
I cannot find any info on a head phone jack. Most TVs do not have one. You can attach a wireless headphone base to the audio out jacks on the back of the set, if there are any.
3/18/2022 1:34:29 AM • Proscan 32LB30QD... • Answered on Mar 18, 2022
Why can we not get our playstation or a digital adapter to hook up to this tv? do we have to do something special?
A basic HDMI Cable is your Solution. Plug it into the TV via the HDMI cable and then put the TV on the proper channel by pressing the "Input" or "Source" Button" on your remote until you get to the one your HDMI cable is plugged into(it's labeled on the tv at the input as "HDMI 1" or "HDMI 2" Etc. You may need to do a reset on your PS System to reset the Display Settings- I've had the same issue as you're having before and you simply reset the PlayStation by holding down the power button until you hear it beep and turn off, keep holding it until it turns on and off again. Now when it is turned back on you should see a message on your screen saying "HDMI Cable Detected" & just follow the instructions on your tv screen! If this was helpful please click click the green button to let me know, best of luck and have a great evening!!! If you need further help, please don't hesitate to ask!
4/14/2019 12:31:55 AM • Proscan 32LB30QD... • Answered on Apr 14, 2019
My proscan 32lb30q won't allow me to switch inputs
First, verify that your computer is sourcing video through the HDMI port rather than looking for an input from it. What happens if you try to select an HDMI input on the TV with no HDMI cable connected? It should select the port, then complain about "No signal." If you get that, turn off the TV and computer, connect the HDMI cable, turn on the TV first, then the computer. There are certain HDMI input chips on the market that are very vulnerable to static electricity damage, and some cheap HDMI switches will conduct a static discharge from the switch mechanism to the HDMI lines (a friend blew two chips that way, then he realized both times the input went out when he used the switch). Use a direct cable connection if possible, and avoid putting a fingertip into the free end of an HDMI cable when the other end is the only one connected. Symptoms of static electricity damage may include "no signal" when an active signal source is connected, or some sort of data format error message. I don't know if your TV is programmed to lock out bad ports; I would think there would be some sort of fault indication to go with the lockout.
7/10/2017 1:41:39 AM • Proscan 32LB30QD... • Answered on Jul 10, 2017
Hi, Need help with ProScan TV mo#32LB30QB.
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
7/25/2016 5:39:16 PM • Proscan 32LB30QD... • Answered on Jul 25, 2016
My proscan tv is 2yrs I have lines going down on the screen what wrg
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
6/24/2016 12:29:18 PM • Proscan 32LB30QD... • Answered on Jun 24, 2016
I cannot play a dvd. i cannot switch source to dvd. i have a proscan tv/dvd combo
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean. http://remotesearch.blogspot.com/ Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
5/24/2016 4:53:59 PM • Proscan 32LB30QD... • Answered on May 24, 2016
2answers
The television doesn't turn on. Press the on
Ur main video backlight board is dead,so is ur on/off so on... control pannels board is broken also.
5/15/2016 2:47:40 AM • Proscan 32LB30QD... • Answered on May 15, 2016
The coxial broke off
Cool, what's your question?
4/19/2016 7:34:45 PM • Proscan 32LB30QD... • Answered on Apr 19, 2016
How do I unlock my proscan tv
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ Search the site by type in the "Brand Name" (Exclude the model number) to your device, in the "Search box at the top right of the display window" to get gathered related posts. Unlock procedure and to override the password lock to many popular brand TVs are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
4/12/2016 5:19:52 AM • Proscan 32LB30QD... • Answered on Apr 12, 2016
Small picture in topleft corner. How do i get it back to full screen
Turn off the PIP feature. Look at instructions for remote.
4/3/2016 5:31:35 PM • Proscan 32LB30QD... • Answered on Apr 03, 2016
Red power indicator is on, when try to turn on blue light comes on then shuts down back to red
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
2/16/2016 4:54:47 PM • Proscan 32LB30QD... • Answered on Feb 16, 2016
I only get one channel, Channel 2.
Do a hard reset to this set first. The do a re-tune (auto channel scan). all the available channels on air or cable will be stored in its memory. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
1/29/2016 6:23:47 AM • Proscan 32LB30QD... • Answered on Jan 29, 2016
How do I flip the picture after replacing the main board?
Hi, I had exactly this problem following a Main AV Board swop, after much head scratching I noticed one digit different in the middle of the typically long part number string, replacing the Board again for one with exactly the same number cured the problem, why do manufacturers do this to us.
1/21/2016 5:17:28 PM • Proscan 32LB30QD... • Answered on Jan 21, 2016
32 in proscan lcd tv just turned on tv and colours were all distorted
Try hard reset, unplug TV, wait 10 min. and plug back in. . You may have to reset your setup configuration back to how you preferred. hope this works for you
1/14/2016 2:43:55 PM • Proscan 32LB30QD... • Answered on Jan 14, 2016
Can I buy a remote for this tv
Hi, saw this is posted on Argos site giving the code for proscan TV as Curtis TV to use a Sky Remote.... "SKY>SERVICES>PROGRAM REMOTE> "I don't know code"> select CURTIS as make and first in list should be 2287 or 2587 . Worked for me. Curtis is the maker of the Proscan". If it helps you the link is http://answers.argos.co.uk/answers/1493-en_gb/product/3169986/questions.htm
1/8/2016 11:58:26 PM • Proscan 32LB30QD... • Answered on Jan 08, 2016
Had motherboard replaced in tv, now remote will operate the main tv but not the dvd
have you reset the remote give it atry.
12/24/2015 10:37:17 PM • Proscan 32LB30QD... • Answered on Dec 24, 2015
Getting 3, 2" wide gray/black lines in screen.
Please answer the questions in video to yourself and then give a more detailed description, as there are many reasons depending on what exactly is happening. TV Repair Help for Vertical Horizontal Lines on Your TV Screen...
11/28/2015 4:04:06 AM • Proscan 32LB30QD... • Answered on Nov 28, 2015
Proscan 32LB30QD 32 in. LCD TV Logo
225 questions posted
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proscan Televison & Video
Most Popular Question
red power indicator when try turn blue
  • Televison & Video
