20 Most Recent Proscan PS32500 32" TV Questions & Answers
Proscan PS32500
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site
1/19/2016 5:42:23 PM • Proscan PS32500... • Answered on Jan 19, 2016
Shaw direct remote code for proscan tv
Take your Shaw remote control, and follow the instructions on the back. If that does not work, telephone Shaw, and ask for technical support for TV.
3/2/2015 4:49:43 AM • Proscan PS32500... • Answered on Mar 02, 2015
Why are there Vertical black and color lines along the right side of the screen?
If you've replaced its LOT recently, the replaced one do not match with the original number. The fault is called 'Yoke Rigging". Gopakumar Gopalan Google
8/11/2014 3:31:40 PM • Proscan PS32500... • Answered on Aug 11, 2014
0answers
0answers
2answers
Tv will not turn on.
does it back up while beeping? just kidding - what does the power light on the tv do after you try to turn it on do you hear sound at all? have you tried changing inputs (do you get video on any input) does you see a picture n the tv at all if so is the picture really dark - need a little more info to get you in the right area - probably a power supply or inverter board problem to be honestly with you.
thanks,
michael
2/25/2011 9:39:27 PM • Proscan PS32500... • Answered on Feb 25, 2011
Ok, so I got a RCA remote from 1800-remotes for
Hello
Just try with these four digit codes. Proceedings are given below.
0031 0107 0015 0000 0162 0163
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NOTE: Switch OFF and switch ON the tv with its front panel power control switch [NOT BY REMOTE CONTROL HANSET] before each try.
12/24/2010 5:33:26 PM • Proscan PS32500... • Answered on Dec 24, 2010
On the back of the
that is for any updates the mfg needs done to the unit.  do NOT plug your stuff in there...
7/28/2010 6:30:18 PM • Proscan PS32500... • Answered on Jul 28, 2010
I have a ProScan Model
Internal speakers of this tv are very small and will not bear/ got damage instantly by high power output of receiver.
There is no way to utilize tv internal speakers to connect with receiver. Please buy external speakers for your Denon receiver, plug tv audio output jack in receiver input to listen tv sound in external speakers.
Let me know if I misunderstood some thing.
Thanks.
7/19/2010 10:08:27 PM • Proscan PS32500... • Answered on Jul 19, 2010
My proscan tv will not stay on. Bought the TV
Take the tv aparts,check the Power switch see any burn marks,possible not holding connection.U know how to do soldering?Have sodering equipment,resolder the FBT,the Flyback Transformer,the big black block of plastic with the red wire with a cap hookup to the CRT(Tv Tub)
7/2/2010 12:18:23 AM • Proscan PS32500... • Answered on Jul 02, 2010
I have a new proscan tv which we installed about
It's still in warranty call whomever you bought it from to have it repaired
8/11/2009 8:49:31 PM • Proscan PS32500... • Answered on Aug 11, 2009
0answers
32" proscan dual hd tv can't get universal or direct tv remote to work what now
Get a universal from big box and program. If you can find a rca remote, it should be programmed already.
Craig www.classtorations.com
4/8/2009 5:55:59 PM • Proscan PS32500... • Answered on Apr 08, 2009
ProScan PS32500 32"-Picture has white static line & Static/burning smell
It sounds like the circuit board is arching over somewhere. It could be as simply as cleaning and digging out the carbon mark to stop the arching. This is most likely the screen or focus voltage causing this, if there are no parts that have broken down. This will damage the printed circuit board and make things worse the more you let this cook. This could be dangerous for you to mess with because of the high voltage present, so my best advise would be to get this into the repair shop as soon as possible before this board burns up. It should not cost all that much if the CRT board can be repaired. Good Luck
12/3/2008 11:18:15 PM • Proscan PS32500... • Answered on Dec 03, 2008
Proscan PS32500 32" TV Logo
51 questions posted
Top Proscan Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proscan Televison & Video
Most Popular Question
proscan tv
  • Televison & Video
