20 Most Recent Sony FD Trinitron WEGA KV-32HS500 32" TV Questions & Answers
you will need to buy a converter. like this one
http://sewelldirect.com/MayFlash-NTSC-to-Pal-Converter.asp
Sony FD... | Answered on Dec 08, 2015
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any.
Sony FD... | Answered on Feb 04, 2015
Hello
Blinking of standby light on Sony TVs are fault symptoms. You just count the number of blinks exactly and keely, for switiching the tv with its FRONT PANEL POWER ON-OFF SWITCH; and not by the remote control hanset. Do it for atleast three times, and confirm the number of blinks, and inform me through Fixya. OK.
Sony FD... | Answered on Feb 26, 2014
Check the audio settings. Whether it is muted or volume is at '0' stage. Check the speakers. Check the audio output section circuit.
Sony FD... | Answered on Jun 17, 2013
what is the blinking pattern? blink pause blink
Check this link to download the user manual to your Sony TV. It has all details, with illustrations.
Sony FD... | Answered on Oct 13, 2012
the high voltage was shutdown the high voltage exceed to 33k volt which goes to safety mode.you will need to check the regulator in the power supply and the horizontal output transistor.
Sony FD... | Answered on Sep 18, 2012
bad picture tube , new tv
Sony FD... | Answered on Sep 12, 2012
It sounds like its in video mode to me if it actually did turn on. Press the
video button 1 -7 times until it cycles to your screen. (manually press the
video button on the front and just below your tv).
Sony FD... | Answered on Aug 24, 2012
my sony brawia klv32s310 a main board change.after red light blinking 2 times
how coming this? pls help me
Sony FD... | Answered on Aug 14, 2012
I have this Sony KV-32HS500 DA-4 chassis complete service manual,i can email you the power supply circuit or any other parts you may need.Its about 18 megs in size.
Sony FD... | Answered on Jun 20, 2012
replace on the D board
IC6501
IC8002
C6510
C8027
C6532
C8037
Hope this fixes you, if not then alot of other might get theirs fixed. please leave your feedback!
this fix cam from sony tech just 5 minutes ago.
FIxes problems with tv not turning on when cold, very hard to turn on. or people that have to unplug and plug in again to get it to come on. I usually dont give info like this for free as I'm a head tech.
good luck
Sony FD... | Answered on Dec 02, 2011
propably green not working. due to age its hard decision its worth or not to repair, but i recommend to sell for a few bucks to a hobby-freak and buy a new one...
Sony FD... | Answered on Nov 13, 2011
well try replacing the h-out power transistor, hope it do the trick. thanks, please rate and vote
Sony FD... | Answered on Oct 29, 2011
This is a fault solution which can be checked and corrected by you assuming that there is no component failure. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit with some of my tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using Fixya.
Sony FD... | Answered on Sep 13, 2011
flashing indicates a power shut down or an overloading occur in the horizontal stage section...have a qualified technician for servicing
Sony FD... | Answered on Jul 19, 2011
Sony FD Trinitron WEGA KV-32HS500 32" TV Logo
108 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
no power no b no oscillation
  • Televison & Video
