SOURCE: dose not stay cold
you have a defrost problem it could be:bad defrost timer,defrost heater or defrost therm.
SOURCE: Sony DSC H1
Dear Martin,
Thanks for your interest but I don't live in USA. therefor I would recommend please contact nearest Sony Service Center for proper repair of your camera.
Regards,
SOURCE: Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
SOURCE: My Frigidaire side/side has had two compressor failures in 3 yrs
Good question. TO give you an idea Id have to know what kind of failures they were.
1 Grounded, shorted, or open windings indicate an electrical problem. This could be caused by external components or power fluctuations. Or a manufacturer defect in the motor.
2 Stuck or not pumping indicate mechanical problems with what could be the compressor its self (again a manufacturer defect) or non defrosting trouble or contaminated refrigerant oil residue from the first compressor.
To me replacing the drier on any compressor and on most all refrigerant related problems is a requirement. This helps eliminate the contamination in most cases. If you purchased a compressor the drier should also be replaced on domestic refrigerators its usually a copper colored piece 4" to 8" long about 1" dia and same size tubes on both ends close to the 1" area. If your not getting this part replaced each time I feel like your not getting quality work done with comon refrigeration practices. And could lead to such a problem.
Back about 15 years ago one of the big appliance manufacturers were making their sealed compressor parts from composite materials that would not hold up in all environments of use. Compressor failures were rampant. I cant say this is the reason but I can say it cant be either.
SOURCE: Frigidaire uprite freezer won't cool
it's scrap
they use steel lines inside the cabinet and when you unplugged it the lines rusted through
Hello friend, thank you for your post!
I understand that your Frigidaire refrigerator is flashing an error code of H1. This code can stand for a high temperature within your refrigerator. I would recommend performing a reset and you can do that by disconnecting power from it for at least ten minutes. If that does not correct your issue you may need to reach out to your manufacturer for any warranty coverage. Hopefully this information is helpful. -Matt
I appreciate your post, Sharon!
From the information you have provided your Frigidaire side by side refrigerator is displaying an "H1" error code. I was unable to locate that error code but I did find the error code "HI" which stands for high temperature inside of your freezer compartment. Check your freezer is it still cooling? If so it may just be a miscommunication within your refrigerator and you can clear that by disconnecting the power cord for roughly ten minutes. If you continue to experience an issue I would recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Best of luck! -Matt
