Sewing Machines Logo
A
Anonymous Posted on May 02, 2018
My Brother 4000D will not bring the needle up
It got the thread caught up underneath and I dad to cut it free now the needle wont raise
Irene Tulloch
Level 2:
  • Expert 498 Answers
  • Posted on May 02, 2018
Irene Tulloch
Expert
Level 2:
Answers
498
Questions
0
Helped
119499
Points
994
There may still be some thread wrapped around the bobbin mechanism, or in the needle plate, which will stop the needle moving feely.
5 Related Answers
snakehead
Henry Thomas
  • 1074 Answers
  • Posted on Mar 19, 2007
SOURCE: Thread getting caught underneath
you need to replace your shukle that holds the tread bobbing below.it is either slack or broken . if it is slack then you tighten the little screw that holds a cover that gives the thread tension .if its broken then replace it.once the thread is slack below it will cause your thread to bundle up.
oldun1
  • Posted on Feb 28, 2008
SOURCE: Automatic Threading not working
if you damp the end of the thread this seems to cure this
Jan
Leighton buzzard
Anonymous
  • 9 Answers
  • Posted on Jan 06, 2009
SOURCE: Needle thread getting caught in bobbin are on Brother Cs-100
I don't know if this is any help, but I would suggest taking it in to a repair store. So here is a way to find places that repair brothers machines. The place near me has done a great job both times I've gone in. Also they usually don't charge for labor, just parts. If they charge for labor it probably won't be much.
http://www.brother-usa.com/service/
jmgldsmth
Jim Goldsmith
  • 2005 Answers
  • Posted on May 03, 2009
SOURCE: I can't raise the bobbin thread. The needle raises before the bobbin thread can 'catch'
readjust the hook to just grab the thread loop as the needle raises it will take a few tries to get the exact setting for the hook (maybe you will see a mark on the hook shaft to show you where the hook's set screw was located before it slipped)
Anonymous
  • 9 Answers
  • Posted on Jun 14, 2009
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
I have thread caught in the bobbin area preventing the needle from moving. How can I remove this thread?
Cut the thread to the needle with scissors.
Raise the needle out of the way.
Remove the thread with needle nose pliers or tweezers.
My brother 4500D keeps giving me an error message check and rethread upper thread and the thread is bunching underneath my embroidery
If the display reads "Check and rethread upper thread", follow the steps below to resolve the issue:
1. Upper thread may be broken.
2. Upper thread may be caught on the spool on top of the machine.
3. Upper thread spool may have run out of thread.
4. Replace the needle in the machine with a new needle. Your needle could be bent or burred causing the thread to break.
Turn your machine off and rethread the machine from the start.
2helpful
2answers
Bobbin thread keeps getting caught up when i begin to sew about 4 stitches in.
bird nesting is the result of incorrect needle thread tension
adjust the tension tighter
How to thread a brother xl 2230
Do you need the directions for threading the upper thread or the bobbin? For the top thread, place the spool on the pin (pull it up if needed). Then raise the presser foot with the lever and the needle (with the balance wheel on the side) to their highest point. Now work from the right to the left. Hook the thread on the rear thread guide and bring the thread forward and down to the front thread guide. Bring the thread up and pass it through the Take-Up lever. Bring the thread up and back down so that it falls into the slot. Bring the thread down and pull it behind the guide above the needle. Then thread the needle from front to back. If you have put in the filled bobbin, hold onto the thread and use the balance wheel to bring the needle down and back up. Use the upper thread to pull up the bobbin thread and pull several inches of the thread to the back of the machine.
Brother has the manuals and quick set-up guide on the product support page: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=XL2230#.VRHrpaSFr3g . The quick setup guide, http://www.brother-usa.com/VirData/Content/en-US%5CHAD%5CConsumer%5CQuickSetupGuide%5CQSG_XL_2230_EN_3166.pdf , has very good pictures of threading the machine.
I hope this helps.
Bobbin thread wont form a stitch
Hai, Please check the bobbin tension and winding. And cleaning the machine.
2answers
Bobbin does not sew: the upper thread gets tangles underneath but the bobbin thread is not involved
bird nesting indicates that the needle thread tension is not tight enough
pull the thread out as if threading the needle and the tension is close when there is resistance to pulling the thread
My brother pc700 the thread is fraying and some times it breaks
Make sure thread tails are at least 6" long when you put underneath your presser foot. Also, make sure you turn hand wheel toward you until metal take- up lever raises to highest position. Make sure needle inserted ALL THE WAY UP in needle bar goove and secure needle clamp. I M P O R T A N T: presser foot must be raised all the way UP before threading machine and pull thread TAUT when threading machine so thread can locate into the tension slots correctly. Thread still breaks? Please clean bobbin case and feed dogs for fuzz balls, lint, and anyoose broken threads! Hope this helps! If so, please give me rating for my free service. Happy sewing! Jimmy
2answers
The thread keeps breaking and i lost the manuel for brother xl 5130
try rethreading machine
thread tension is to tight -try 3-5-see if that works better
change needles
thread might be caught around spool pin -tension dial
needle & thread may not be compatable-try this & see if it works for you
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
1helpful
Bobbin thread tangling up
are you doing embroidery? if so turn off jump stitch cutting if possible. is the machine threaded correctly (pull needle thread out of machine and thread again with presser foot raised.
check for foreign matter in needle tension assembly. ensure there is sufficient needle thread tension.
the thread you see caught up underneath the fabric will be needle thread and indicates insufficient needle thread tension or something preventing the needle thread from being pulled up into the fabric (maybe a damaged bobbin case, or bobbin case position finger, or damaged needle plate hole).
goodluck,
scott
Jan
Leighton buzzard
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
