20 Most Recent Brother XL-5130 Mechanical Sewing Machine Questions & Answers
Oil any moving part that you can see or get to
Brother XL-5130... | Answered on Jul 11, 2019
get the motor switch control fixed
Brother XL-5130... | Answered on Aug 25, 2017
Probably depends where the break occurred. If there is still a piece of the spool pin in place, you can try slipping a piece of a plastic drink straw (like the drink straws at MacDonald's) over the remaining piece and using it as a spool pin. You may be able to find a handyman who can create an alternative. Or you can take it for service.
Brother XL-5130... | Answered on May 09, 2017
check that you have the correct needle
some machines use a needle with a flat side that correctly aligns the eye with the hook
and others just have a round needle that you have to take care in installing it
I suspect that your machine requires needles with a flat side if there is a small block stopping the needle from going in
read your operators manual or discuss it witj a sewing machine retailer
Brother XL-5130... | Answered on Oct 07, 2016
What exactly is the problem. It doesn't come one? It won't form a stitch? "doesn't work" is way too vague to get help.
Brother XL-5130... | Answered on Aug 16, 2016
Buy a new pack of needles to make sure you do not have defective needles, if that doesnt work get a new thumb screw and if it still doesnt work you need a new needle bar.
Brother XL-5130... | Answered on Mar 22, 2016
Could be what is called thread nesting or bird nesting.
The first thing to try is installing a brand new needle in your machine. Then try the following suggestions:
sewing machine birdnesting
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
3 Common Sewing Machine Problems and How to Fix Them
Brother XL-5130... | Answered on Nov 30, 2015
SORRY I have no idea but perhaps a repair shop can fix it .
Brother XL-5130... | Answered on Sep 11, 2015
This is no exception, Please take your machine to a authorized repair shop to have the machine repaired properly. Note: Most machine manufacturers do not sell parts to the public! Ill repaired machines can be dangerous to use is most cases.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Brother XL-5130... | Answered on Mar 02, 2015
Have you tried bees wax?
Brother XL-5130... | Answered on Nov 21, 2014
The needle holder has a screw right above the screw that holds the needle in place. It really doesn't look like a screw because it does not appear to have a slot for a screwdriver. However, with a small flat head screw driver you can tighten it up. There is also a curverd wire that must be inserted into a slot at the bottom of the holder. The screw tightens against the wire that tightens against the post. (It's a curved wire that curves around the front part).
Brother XL-5130... | Answered on Jul 18, 2014
Just start over threading, that's usually the problem.
Brother XL-5130... | Answered on Jul 07, 2014
Brother XL-5130 Mechanical Sewing Machine Logo
221 questions posted
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Brother Sewing Machines
Most Popular Question
oil euro pro 473b
  • Sewing Machines
