Hi there, For few reason camera showing memory card error.
1. Memory card damaged.
2. your memory card finished is life time storage memory.
3 . virus infected.
4. If your memory card storage capacity more than camera support card then its also show to you. For example your camera support maximum 2 GB card, but your try to use more than 2 GB memory card.
I suggest your remove the memory card and scan by updated antivirus. After that, if not working then fomat it and try.
Thanks & waiting for your feedback.
remove the memory stick, you should be able to see the backend of the stick, push it in and it will pop out. after removing the stick try operating the camera again.
try to remove the memory of your camera and din insert again or try to replace other memory when the error e 45 dosn't apear it main the memory is your problem buy the new memory or try to format all files to your memory
This is a memory error. First remove all your memory then put it back in again. If the error persists and you have more than one memory module, remove one at a time and see if it will boot. If you only have on module, then that module will have to be replaced.
Try starting it in Safe Mode (hit F8 key at boot-up). If you see the error "Page_Fault_in_nonpaged_Area stop", you have bad memory usually. If you have 2 memory modules installed, remove one and reboot. If you get the error, remove that memory module and install the other. If it boots cleanly, you have a bad memory module.
Many times when someone fools with a memory card and the camera is on, it sort of backfires when the camera is trying to read or write data to the memory card. Error 10 might be attached to a fault in the memory card or system error. Try doing this first: remove you memory card when the camera is off. Remove you batteries so it can reset. Leave the batteries out for 30 secondsthen replace them. Use a brand new SD memory card and then turn on camera. Go to menu and format the new memory card and see if this helps. Good luck.
First step involves that you check if the memory card is password protected or not.if yes remove it and then try.this time it will work definitely .memory which are password protected are not accessed by computer and sometime you can get blue screen error also.so first remove password from memory card....let me know if this works
Error saving image
or
Error saving video.
The optional
memory card that
is installed was
removed before
the camera
finished writing to
the card or was
half-locked.
Always wait until the
Memory light stops
blinking before removing
the memory card from
the camera.
With the camera turned
off, remove the memory
card and check to see if
the locking tab on the
edge of the card is fully
in the unlocked position.
