Canon PowerShot S3 IS Digital Camera Logo
Posted on Jul 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Canon S3 Lens Error
I'm got a similar problem. My camera was dropped in some sand. I thought there was no problem as it worked for about 2 months. Now I get a lens error and am told to restart the camera. When I turn it on the lens may or may not go out or go out part way before giving me the error.Pushing the off button repeatedly and it will retract completely.
Any suggestions?
Anonymous
Level 2:
Novelist:
  • Expert 164 Answers
  • Posted on Jul 22, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
164
Questions
0
Helped
50548
Points
222
There two possible scenarios:
1. Sand particles got stuck in the internal lens mechanism. Try in remove them with compressed air, blowing it through the camera lens openings. If this does not work, then here are the bad news.
2. Either the lens internal gears are damaged, the ultrasonic motor is damaged, or sand particles are really stuck inside the lens.
It does not matter which of the three reasons are casuing the problem, but the camera needs to be opened by a qualified technician, defined thereason of the failure, and quoted the repair service, unless you are willing to do it yourself, but it requires a complete disassembly of the camera, and I don't recommend it unless you have the experience and skills in fixing electronic devices.
Best regards,
I get a Lens Error for my canon S3 IS digital camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
2answers
Lens error says restart camera how to restart canon S3iS camera
Hello
Unfortunately a "lens error" message is not something that you will be able to fix. This error indicates a system failure and requires the camera to be sent in for servicing and repair.
1helpful
When i turn on my canon powershot s3 iS , it says lens error restart camera. i tried restarting it , but my when my lens are trying to come out it makes a jammed noise. CAN YOU PLEASE HELP ?!
1helpful
Where is the reset button on the powershot s3 IS
"Lens error, "Restart" camera", means to try turning the camera off and on to see if that corrects the problem. Unfortunately, it rarely does.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Error message Lens error restart camera Lens is stuck partially open. Have replaced batteries and it's still stuck.
My Canon S3 lens will out out and then give me lens error message. Repeatedly pushing off button and it will eventually full retract. It was dropped in sand but worked fine for about 2 months after that....
You need to take your camera to the nearest service centre to get it back into action. Whenever there is such an accident (sand, water, fell off) you should take your camera immediately to the service centre.
Lens error , restart camera
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
2answers
Problem with the lens
Apr 25, 2009 • Cameras
3answers
Lens error Help please
The Lens Error usually means the lens has sand or another obstruction stopping it from retracting.
3helpful
2answers
Canon SD600 lens jam
I followed the directions contained in http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/ and by disassembling the camera and turning the rotor just a little bit (page 4 of the instructions), it freed up the lens and it is now working perfectly! The camera had been put down on the lens as the lens was retracting and I assume that jammed the retract mechanism. While the camera was open, I blew out whatever dust/dirt was there (didn't see much). The fix took me probably 20-30 minutes, and I am very pleased with myself!
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
