20 Most Recent Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Questions & Answers
nothing with out taking it apart.
Canon PowerShot... | Answered on Jan 09, 2018
I would update your audio and video codecs in the computer. There's the source of the stuttering on playback.
Canon PowerShot... | Answered on Oct 31, 2017
The technical term for this is 'broken'. Repair will cost more than replacement.
Canon PowerShot... | Answered on May 07, 2017
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Canon PowerShot... | Answered on Nov 06, 2015
I don't know that there is a lock on the on/off button. Take the battery out for a minute, put it back in and try.
Canon PowerShot... | Answered on May 28, 2015
Had this happen with the lens stuck in the retracted position. Rapped the camera on my palm to jostle the lens a bit, turned it on and back to normal.
Canon PowerShot... | Answered on Nov 07, 2014
I had the same problem, tried different things but this is what worked.
I put the camera flat on its "back" (screen down, lens up). Looking down at the lens I could see that it was slightly off center. I pushed the lens towards the center and down, forcing it to close. Once it was centered I was able to turn it on and off no problem.
Canon PowerShot... | Answered on Dec 25, 2013
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Canon PowerShot... | Answered on Oct 28, 2013
What type and size memory card? The SD630 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
If you are using an SD card, have you tried formatting it?
Canon PowerShot... | Answered on Jul 13, 2013
Dear jmgrev,
Whenever you turn your camera on and your lens doesn't go in and out properly you are likely experiencing a lens error of some sort. Look for an error 18 or a "lens error restart camera" message. If either of these appears you definitely have a lens motor mechanism problem and will need to send the unit in for service.
If the lens still functions, but only intermittently - or if there seems to be a functional problem in focusing correctly or in taking an excessive time to focus, then you are in the early stages of what will soon become a fullblown lens issue.
These problems can be caused by a variety of things such as having obstructed the lens when turning the camera at one point, or getting grit in the lens mechanism or during/after a fall or some sort of impact. It can even happen spontaneously due to the tracking mechanism coming out of gear. Hopes this helps.
Sincerely,
HeavyDLB
Canon PowerShot... | Answered on Apr 21, 2013
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or attached via USB). This is likely to be faster than connecting the camera to the computer, and will work with any future cameras you may acquire.
Once the card is plugged in, it will appear to your computer as a removable hard drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Canon PowerShot... | Answered on Apr 04, 2013
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
416 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
memory card error
  • Cameras
