SOURCE: Inner Cover error on Canon PIXMA ip4300 printer
This is a "Sensor" issue, there is a sensor that detects when the Cover is closed, this is either faulty, not being activated, or being activated but not registering at the CPU. Sometimes it is an actual switch, others it is a hall effect sensor, optical, magnetic sensor or the like. Have a squiz and see if ya can see any sensor etc. maybe its blocked etc. Otherwise I think it's gonna have to go 4 repair.. If so get a firm "Quote" B4 allowing them to proceede.
SOURCE: When attempting to print, I
Are you looking at the canon error window picture that show up on your monitor: It is the front inner flap you see after you open up the two top "covers". I forgot I opened this one looking for a paper jam. The printer cartridges would not even move to the front with this flap opened. After I closed the inner flap it all works (after opening and closing the top two "covers" many times!
SOURCE: my mp600 keeps saying close inner cover-which is closed
I had the same issue, turning off didn't solve it.
There's a plastic flap the width of the print tray just inside that I flipped up and it solved this problem. It is directly in front of the ink tanks. I'm assuming we flipped it down and forgot about it. It seems it needs to stay up, although you wouldn't notice it when it flips down when you close the top, as it closes just fine with it down. It's easy to overlook. This took me a few hours to realize.
The top of the flap has a half circle cut out of it in the middle.
SOURCE: cant print on cd with canon mx850 printer
Those links might solve your problem:
http://damnprinter.com/105/the-five-easy-steps.html
http://damnprinter.com/176/tray-rejection-general-guide.html
How To Print on CD / DVD Tutorials on youtube
http://www.youtube.com/results?search_query=canon+cd+print&search_type=&aq=f
cheers :)
PS: Btw, info for others: For the Canon MX850 I was searching for the
tray feeder itself! For this printer it is inside, i.e. look straight
into the paper output and pull/open softly the black panel...
SOURCE: getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
