20 Most Recent
Canon LASER SHOT LBP-2900 Printer Questions & Answers
Canon lbp 2900 300dpi drivers
I have canon lbp 2900 printer
in this printer i want to prit picture in 300dpi resoulition
how to print, that way i want printer 300dpidrivers
How to use the canon
i have one canon printer LBP 2900 but that is not proparly working on my pc
see problem is this
my Canon printer has not printer office 7 file
Cannon laser shot printer lbp
1.http://files.canon-europe.com/files/soft38030/software/LBP2900_R113_V310_Win_x64_EN_7.exe
2.http://www.microsoft.com/windows/compatibility/windows-7/en-us/Details.aspx?type=Hardware&p=Canon%20Laser%20Shot%20LBP2900%20Laser%20Printer&v=Canon&uid=0017B009&pf=0%26%23960%3B=0&s=lbp2900&os=64-bit
This is your download link for win-7 64/32 bit.
How cancel the print job in cannon lbp 2900
Hi and welcome to fixya,
Go to control panel > Devices and Printers
double click your printer, you'll be able to see the queue...Right click on the document and select Cancel printing.
You can alternately push the power button to immediately stop the current page being printed. You will receive an error message but click cancel and proceed normally.
Hope this helps
Error code e747 0000
Error code is E747 may be a major cause: There is a fault in the video controller memory
To Fix Error code E747 on a Canon LassetJet LBP-2900 printer, you can try the following: replace the video controller PCB
Try use the printer on another PC you get the same error code return it from where ever you bought it or you will have to get it repaired.
Laser scanner unit error.
Turn off
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
My printer is displaying "Print Server Down". How can I fix this error?
this printer has a usb interface can you see an axis 1650 usb to ethernet server box attached to the usb cable that is attached to the printer ?
would check power to the usb to ethernet server box see photo inserted of what it looks like !
Maybe the power has been disconnected or the ac-dc adapter has gone faulty .
If it has power may be try removing power from it for 20 seconds and then re plug in and then test by printing to printer.
check print server has valid ip address.
also check dhcp server on network has not got printer servers ip address in its lease range. check also that printer server's ip address is static and not being set automatically.
if printer server is ip address try going to dos prompt on p.c. and type in ping {ip address of server} eg c:> ping 192.168.0.2
press Enter key
should get a reply 4 times
